Xyz Steps.
Vargsh0rd3
Ok so im at a loss.
Was following a guide on YouTube  and I made it to the end, or to where I was about to configure klicky. And I noticed my machine measures distance severely distorted.
If I go to the front left corner and hit home. Itll make it  264 mm
If from a homed position manual clicking 100 etc to a max of (alleged)350, the machine only makes it 174mm. I've looked over everything to do with:
Rotation Distance: 40
Microsteps 32
And steps per rotation 200
Using standard motors that come with LDO.
Tried the calculator from prusa and they just give me these values.
This isn't a few mm its a lot.  There's 80 mm just over 3 inch difference between auto home and using the manual buttons.
Belts are tight.
All the min max stuff is all what it's supposed to be.
Edited by Vargsh0rd3
2 answers to this question
These are indeed the defaults for NEma17 motors LDO or Moons.. (and many others)
Whats the run_current, just making sure its not losing steps, but I expect not.
After that, I would switch steppers (not the motors but the drivers) maybe with a Z motor, just to see if it makes a difference.
Is it constant? or if you do the same thing 3 times, its exactly the same?
The config looks right for a NEMA17 1.8deg motor. A thought occurs to me: what pulleys are on it? If those don't match the spec I think that might mess things up. Like having a 16 or 25 tooth where it's expecting a 20 tooth.
BTW, welcome to the forum. Think about posting in the Introductions board to...introduce yourself.
