Mellow Fly LLL Pro Filament Buffer
8 hours ago, PFarm said:
Thank you for the awesome assembly guide tested my buffer this morning had to slightly enlarge the hole the filament passes through on the PTFE guide. It works flawlessly 👌
Always happy to help -glad it came together so well!
Finally got my Mellow Buffer installed, was waiting on replacing the CB1 in my Manta 8P with a CM4 module. A word of advice: when installing the filament sensors module, ensure that all of the pins are properly inserted. The filament feed wasn't stopping because the sensor module wasn't installed properly. It's so nice not to have the " MCU too close" error!
Also glad to report the issue with the Orbiter filament sensor flashing between yellow and green is gone with the installation of the buffer. The issue was that Nylon filament is a lot stiffer than other filaments, and the PTFE tube was being pulled up and triggering the yellow LED.
4 hours ago, therm_virtual0y said:
I think there is a selection [Stepper Step Both Edge] when performing “Make Config” that needs to be selected.
Thanks, I double-checked my menuconfig setup, and that was checked. I ssh into the printer and did an update, and the error seems to be gone.
