- 0
Wannabe
So I want to install 2 or 3 led strips along the top frame extrusions before I put the panels on and finally call it a day on my V2.4 x 300 build.
I have some led strip left over, white 5000K 12 volt that I want to use up and at least test it out to see how it looks.
My intention is too run the leads of each strip to a common negative and postive wago, then from the respective wagos just have a single postive and negative wire coming together into a spare fan header on my Octopus 1.1 board, switching the voltage on that particular header to 12 volt.
My question would be is this an accepatable method of wiring the led strips without causing some other issue?
Edited by WannabeLink to comment
2 answers to this question
