- 0
Wannabe
I just finished my build, V2.4 as per BOM, CW1 with hartK PCB, Octupus V1.x.
Klipper and mainstail installed and configured without any apparent issues, initial startup checks complete with no issues, SuperSlicer setup and configured with no issues.
A couple of small test prints completed with minimal issues.
So everything seems in order expect for the fact that the Part Cooling Fan starts up immediately on power up and stays on.
Mainsail Dashboard indicates fan is turned off, adjusting the slider to 100% does nothing, LCD panel on printer shows fan is turned off, also any adjustments on the lcd does nothing.
Double checked my wiring on board FAN0 pin: PA8. Printer.cfg reflects correct pin assignment.
Double checked wiring on PCB and that appears correct also.
Hotend Fan working correctly as FAN1 PE5
Any suggestions at what I should be looking at
6 answers to this question
