- 0
Rede
Hi, I need your help.
I'm struggling to print with my LDO Voron 2.4, as I can't get the material (I've tried ABS, PETG, and PLA) to stick to the print bed. I've tried everything.
For ABS (what interests me most), I have used hairspray, glue, ABS juice, sugar, and even a "bare" plate, but nothing sticks. I even tried "roughening up" the plate with a metal scrubber and cleaned it with acetone, brake cleaner, dish soap, and alcohol—still nothing.
For Esun ABS, I have tested different temperatures, ranging from 245 to 270°C for the hotend and 90 to 120°C for the bed.
What am I doing wrong? Everything is perfectly calibrated. The only time ABS adhered was when I pressed it hard against the bed, but as you can imagine, the print turned out terribly.
If the stock LDO plate is just bad, could you recommend a suitable print plate for the 350mm version?
Thanks a lot!
Edited by RedeLink to comment
4 answers to this question
