2 Probes in Klipper?
DC67
Hello. I converted my Voron 2.4 SB to a Revo hotend. Here I installed the PZ_Probe from E3D with the coldend. I switched the cartographer that I used before in touch mode to scan. Why PZ_Probe? Because the cartographer in touch mode was always too far away for the first shift. Too far away means 0.3-0.4mm.The magnetbed may interfere with the cartographer when scanning. I also often got the error that the scanner was out of range. Hence my idea that I use the scanner for bed mesh and measure PZ sample for the first layer. Now I get the error that I have the chip sample twice. If I read correctly then you can only use 1 Probe in Klipper?
0 answers to this question
There have been no answers to this question yet
