  • 0
Voron 2.4r2 Ldo stepper motor kit,question about current.
SamppaD
Hi. My build is almost completed and i have a question about setting correct current values for ldo motors
At the moment my Z drives motors  1.8° ldo-42sth48-2004ac are set at  0.8A   (max current is 2A)
A-B motors are  0.9° ht ldo-42sth48-2004 mah(vrn) current set  at 0.8A   (max current is 2A)
Extruder  1.8° ldo-36sth20-1004ahg(vrn) current set 0.8A  (max curent is 1A)
For a heavy gantry (CNC parts) and a Z drives holding it 0.8A seems way to low. So can anyone suggest what would be correct value to set in printer.cfg.
Thanks.
config-20241229-103117.zip
7 answers to this question
  • 0
Hi and thanks for fast reply. I was thinking like 1.2A on AB motors and Z drives. 0.8A must be a default value in printer.cfg. It does works but its on limit with torque on Z drives. Extruder motor is fine max current is 1A and set current is 0.8A. So its good to go,so to say. 🙂
Edited by SamppaD
  • 0
HiI will be setting current to 1.2ABy the way is there any mod to remove front doors on 2.4R2 and replace it with one peace poly-carbonateI have a randells mod doors, and now second door panel  kit cracking again with 3mm thick panels . Panels are intended for this mod and pre-made by 3D companyIssue is that after opening and closing doors for short time, front doors panels start to crack around holesSo i was thinking to replace it with a one piece panel...
Edited by SamppaD
  • 0
Yes the clicky clacky door mod
  • 0
Go to the clicky clacky fridge door mod. It's great.
  • 0
If you are running tcm2209 or some driver version and enable uart mode you can put the motor suppliers maximum. I lower mine to 80 percent and can run up past 600 with no issues. I also enable stallguard. There is a great tutorial on this.
Answer this question...
