- 0
Neo
Hi folks,
i tried to figure it out myself but am not able get it working.
First of all my 2.4 was running fine with 2209´s but after a break of nearly 2 months it is behaving crude and destroyed a printbed and nozzel.
I did not observe the first layer truth to be told but why it normally worked fine.
Anyway i changed the print start macro with the online tool, works fine so far, an it accelerated the print start process. Configured z-offset and started a new print.
But now i get layer shifts from hell!
My conclusion was:
1. Drivers overheating or defect
2. Motors defect
Changed first the drivers to new 2209 but same result.
Changed the motors but same result.
Now i bought TMC 5160 drivers, set the jumpers as described for spi, but am not able to get them running. I stumble fom one error message to a new.
Does any of you got a working printer.cfg for xy with 5160 or can tell me what to change in my config.
The current error message is:
My config is:
# This file contains common pin mappings for the BigTreeTech Octopus
# and Octopus Pro boards. To use this config, start by identifying the
# micro-controller on the board - it may be an STM32F446, STM32F429,
# or an STM32H723. Select the appropriate micro-controller in "make
# menuconfig" and select "Enable low-level configuration options". For
# STM32F446 boards the firmware should be compiled with a "32KiB
# bootloader" and a "12MHz crystal" clock reference. For STM32F429
# boards use a "32KiB bootloader" and an "8MHz crystal". For STM32H723
# boards use a "128KiB bootloader" and a "25Mhz crystal".
# See docs/Config_Reference.md for a description of parameters.
## *** THINGS TO CHANGE/CHECK: ***
## MCU paths [mcu] section
## Thermistor types [extruder] and [heater_bed] sections - See https://www.klipper3d.org/Config_Reference.html#common-thermistors for common thermistor types
## Z Endstop Switch location [safe_z_home] section
## Homing end position [gcode_macro G32] section
## Z Endstop Switch offset for Z0 [stepper_z] section
## Probe points [quad_gantry_level] section
## Min & Max gantry corner postions [quad_gantry_level] section
## PID tune [extruder] and [heater_bed] sections
## Probe pin [probe] section
## Fine tune E steps [extruder] section
# MCU & Printer Kinematic
[mcu] ## Obtain definition by "ls -l /dev/serial/by-id/" then unplug to verify
# serial: /dev/serial/by-id/usb-Klipper_stm32f446xx_250028000251313133353932-if00
serial: /dev/serial/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.4:1.0
restart_method: command
# CAN bus is also available on this board
[printer]
kinematics: corexy
max_velocity: 300
max_accel: 3000
max_z_velocity: 5
max_z_accel: 100
[include mainsail.cfg]
[include macros.cfg]
[include stealthburner_leds.cfg]
# Enable arcs support
[gcode_arcs]
resolution: 0.1
# X/Y Stepper Settings
## B Stepper - Left
## Connected to MOTOR_0
## Endstop connected to DIAG_0
# Driver0
[stepper_x]
step_pin: PF13
dir_pin: !PF12
enable_pin: !PF14
microsteps: 16
rotation_distance: 40
full_steps_per_rotation:200 #set to 400 for 0.9 degree stepper
endstop_pin: PG6
position_min: 0
position_endstop: 350
position_max: 350
homing_speed: 50 #Max 100
homing_retract_dist: 5
homing_positive_dir: true
[tmc5160 stepper_x]
cs_pin: PC4
spi_bus: spi1
diag1_pin: x_diag_pin
run_current: 0.800
stealthchop_threshold: 999999
#[tmc2209 stepper_x]
#uart_pin: PC4
#diag_pin: PG6
#run_current: 0.800
#stealthchop_threshold: 0
## A Stepper - Right
## Connected to MOTOR_1
## Endstop connected to DIAG_1
# Driver1
[stepper_y]
step_pin: PG0
dir_pin: PG1
enable_pin: !PF15
microsteps: 16
endstop_pin: PG9
position_min: 0
position_max: 350
[tmc5160 stepper_y]
cs_pin: PD11
spi_bus: spi1
#diag1_pin: y_diag_pin
run_current: 0.800
#[tmc2209 stepper_y]
#uart_pin: PD11
#diag_pin: PG9
#run_current: 0.800
# Z Stepper Settings
# Driver2
[stepper_z]
step_pin: PF11
dir_pin: PG3
enable_pin: !PG5
gear_ratio: 80:16
microsteps: 32
endstop_pin: !PG10
#position_endstop: 1.5
position_min: -2
position_max: 400
[tmc2209 stepper_z]
uart_pin: PC6
diag_pin: PG10
run_current: 0.800
# Driver3
#[stepper_z1]
#step_pin: PG4
#dir_pin: !PC1
#enable_pin: !PA0
#rotation_distance: 40
#gear_ratio: 80:16
#microsteps: 32
#[tmc2209 stepper_z1]
#uart_pin: PC7
#run_current: 0.650
#stealthchop_threshold: 999999
# Driver7
[stepper_z1]
step_pin: PE6
dir_pin: !PA14
enable_pin: !PE0
gear_ratio: 80:16
microsteps: 32
uart_pin: PD3
run_current: 0.800
# Driver4
[stepper_z2]
step_pin: PF9
dir_pin: PF10
gear_ratio: 80:16
microsteps: 32
enable_pin: !PG2
[tmc2209 stepper_z2]
uart_pin: PF2
run_current: 0.800
# Driver5
[stepper_z3]
step_pin: PC13
dir_pin: !PF0
gear_ratio: 80:16
microsteps: 32
enable_pin: !PF1
[tmc2209 stepper_z3]
uart_pin: PE4
run_current: 0.800
# Extruder
# Driver6
[extruder]
step_pin: PE2
dir_pin: PE3
enable_pin: !PD4
microsteps: 128
## Update value below when you perform extruder calibration
## If you ask for 100mm of filament, but in reality it is 98mm:
## rotation_distance = <previous_rotation_distance> * <actual_extrude_distance> / 100
## 22.6789511 is a good starting point
rotation_distance: 22.6789511 #Bondtech 5mm Drive Gears
## rotation_distance: 4.637 #Orbiter 2.0
## Update Gear Ratio depending on your Extruder Type
## Use 50:10 for Stealthburner/Clockwork 2
## Use 50:17 for Afterburner/Clockwork (BMG Gear Ratio)
## Use 80:20 for M4, M3.1
gear_ratio: 50:10 #50:10 BMG Gear Ratio
nozzle_diameter: 0.600
filament_diameter: 1.750
heater_pin: PA2 # HE0
sensor_pin: PF4 # T0
sensor_type: Honeywell 100K 135-104LAG-J01
#control: pid
#pid_Kp: 22.2
#pid_Ki: 1.08
#pid_Kd: 114
min_temp: 0
max_temp: 350
[tmc2209 extruder]
uart_pin: PE1
run_current: 0.800
# Heated Bed
[heater_bed]
heater_pin: PA1
sensor_pin: PF3 # TB
sensor_type: Generic 3950
#control: watermark
min_temp: 0
max_temp: 130
# Probe
## Inductive Probe
## This probe is not used for Z height, only Quad Gantry Leveling
## Z_MAX on mcu_z
[probe]
## If your probe is NO instead of NC, change pin to !^z:P0.10
pin: PG15
x_offset: 0
y_offset: 25.0
z_offset: -1
speed: 10.0
samples: 5
samples_result: median
sample_retract_dist: 3.0
samples_tolerance: 0.006
samples_tolerance_retries: 3
# Homing and Gantry Adjustment Routines
[idle_timeout]
timeout: 1800
[safe_z_home]
## XY Location of the Z Endstop Switch
## Update -10,-10 to the XY coordinates of your endstop pin
## (such as 157,305) after going through Z Endstop Pin
## Location Definition step.
home_xy_position:121,345
speed:100
z_hop:10
## Use QUAD_GANTRY_LEVEL to level a gantry.
## Min & Max gantry corners - measure from nozzle at MIN (0,0) and
## MAX (250, 250), (300,300), or (350,350) depending on your printer size
## to respective belt positions
[quad_gantry_level]
## Gantry Corners for 350mm Build
gantry_corners:
-60,-10
410,420
## Probe points
50,25
50,275
300,275
300,25
speed: 100
horizontal_move_z: 15
retries: 5
retry_tolerance: 0.0075
max_adjust: 10
[bed_mesh]
speed: 100
horizontal_move_z: 10
probe_count: 5, 5
mesh_min: 40, 40
mesh_max: 310,310
# Fan Control
## Print Cooling Fan - FAN0
[fan]
pin: PA8
kick_start_time: 0.5
## Depending on your fan, you may need to increase this value
## if your fan will not start. Can change cycle_time (increase)
## if your fan is not able to slow down effectively
off_below: 0.10
## Hotend Fan - FAN1
[heater_fan hotend_fan]
pin: PD13
max_power: 1.0
heater: extruder
heater_temp: 50.0
## If you are experiencing back flow, you can reduce fan_speed
#fan_speed: 1.0
## Controller fan - FAN2
[controller_fan controller_fan]
pin: PD12
heater: heater_bed
## Exhaust fan - FAN3
#[heater_fan exhaust_fan]
#pin: PD13
#max_power: 1.0
#shutdown_speed: 0.0
#kick_start_time: 5.0
#heater: heater_bed
#heater_temp: 60
#fan_speed: 1.0
# Displays
# MKS Mini 12864Panel v3.x (with neopixel backlight leds)
[display]
lcd_type: uc1701
cs_pin: EXP1_3
a0_pin: EXP1_4
rst_pin: EXP1_5
contrast: 63
encoder_pins: ^EXP2_5, ^EXP2_3
click_pin: ^!EXP1_2
## Some micro-controller boards may require an spi bus to be specified:
#spi_bus: spi
## Alternatively, some micro-controller boards may work with software spi:
spi_software_miso_pin: stepper_spi_miso_pin
spi_software_mosi_pin: stepper_spi_mosi_pin
spi_software_sclk_pin: stepper_spi_sclk_pin
#spi_software_miso_pin: EXP2_1
#spi_software_mosi_pin: EXP2_6
#spi_software_sclk_pin: EXP2_2
[output_pin beeper]
pin: EXP1_1
[neopixel mks_mini12864]
pin: EXP1_6
chain_count: 3
color_order: RGB
initial_RED: 1.0
initial_GREEN: 0.0
initial_BLUE: 0.0
[board_pins]
aliases:
# EXP1 header
EXP1_1=PE8, EXP1_2=PE7,
EXP1_3=PE9, EXP1_4=PE10,
EXP1_5=PE12, EXP1_6=PE13, # Slot in the socket on this side
EXP1_7=PE14, EXP1_8=PE15,
EXP1_9=<GND>, EXP1_10=<5V>,
# EXP2 header
EXP2_1=PA6, EXP2_2=PA5,
EXP2_3=PB1, EXP2_4=PA4,
EXP2_5=PB2, EXP2_6=PA7, # Slot in the socket on this side
EXP2_7=PC15, EXP2_8=<RST>,
EXP2_9=<GND>, EXP2_10=PC5
# LED Control
## Chamber Lighting - HE2 Connector (Optional)
#[output_pin caselight]
#pin: PB10
#pwm:true
#shutdown_value: 0
#value:1
#cycle_time: 0.01
#[neopixel my_neopixel]
#pin: PB0
#[filament_switch_sensor material_0]
#switch_pin: PG12
#[filament_switch_sensor material_2]
#switch_pin: PG14
#heater_pin: PB11 # HE3
#sensor_pin: PF7 # T3
#[filament_switch_sensor material_3]
#switch_pin: PG15
## Thermistor Types
## "EPCOS 100K B57560G104F"
## "ATC Semitec 104GT-2"
## "NTC 100K beta 3950"
## "Honeywell 100K 135-104LAG-J01"
## "NTC 100K MGB18-104F39050L32" (Keenovo Heater Pad)
## "AD595"
## "PT100 INA826"
#*# [heater_bed]
#*# control = pid
#*# pid_kp = 51.525
#*# pid_ki = 1.817
#*# pid_kd = 365.182
#*# [extruder]
#*# control = pid
#*# pid_kp = 18.903
#*# pid_ki = 0.696
#*# pid_kd = 128.304
#*# [stepper_z]
#*# position_endstop = -0.025
#*# [bed_mesh default]
#*# version = 1
#*# points =
#*# 2.901250, 2.891250, 2.908750, 2.902500, 2.901250
#*# 2.831250, 2.800000, 2.797500, 2.783750, 2.786250
#*# 2.807500, 2.778750, 2.765000, 2.751250, 2.756250
#*# 2.827500, 2.796250, 2.787500, 2.780000, 2.802500
#*# 2.927500, 2.885000, 2.867500, 2.880000, 2.912500
#*# x_count = 5
#*# y_count = 5
#*# mesh_x_pps = 2
#*# mesh_y_pps = 2
#*# algo = lagrange
#*# tension = 0.2
#*# min_x = 40.0
#*# max_x = 310.0
#*# min_y = 40.0
#*# max_y = 310.0
Sorry to bother you with this but right now i have no clue what to change.
And sorry for my faulty denglish;)
Greetings from Frankfurt am Main
Neo
1 answer to this question
