Initial setup of ERCF - # of gates and Encoder Issues
Muldoon
I have everything printed and wired, and am at the beginning of the process of setting up / configuring Happy-Hare 2.0
https://github.com/moggieuk/Happy-Hare
https://github.com/FYSETC/FYSETC-ERB
Issue #1
In mainsail (which is fully updated), when I run MMU_CALIBRATE_SELECTOR it says the following:
You configued your MMU for 6 gates but I counted 5! Please update `mmu_num_gates`
Maximum selector movement is 116.5mm
Measuring the full selector length...
Searching for end of selector... (up to 148.4mm)
Measuring the selector position for gate #0...
Auto calibrating the selector. Excuse the whizz, bang, buzz, clicks...
mmu_calibrate_selector
I have the following in mmu_parameters.cfg
mmu_vendor: ERCF            # MMU family
mmu_version: 2.0            # MMU hardware version number (add mod suffix documented above)
mmu_num_gates: 6             # Number of selector gates
Issue #2
When I run mmu_encoder, it always says
Encoder position: 0.0
Clog/Runout detection: Automatic (Detection length: 15.0)
Trigger headroom: 20.0 (Minimum observed: 15.0)
Flowrate: 0 %
What troubleshooting steps do I need to do?
  • 5 months later...
