- 11
A proper filter box for using Roomba 800/900 series HEPA filter in your Voron 2.4 Exhaust.
Unlike the other HEPA box posted here, this one fits the original exhaust housing and should use less material.
Print with Filter insert side on bed with support on build plate only.
To install it in the exhaust box, insert it at 90C angle and rotate it as you insert (last pic). The last push to lock it in place might require you to push from inside the printer. You might have to temporarely remove the fan for installation!
