Showing results for tags 'rabbit hole'.
  • Other FDM Printers / CNC
    • Bambu Labs
    • CNC
Found 1 result
  1. I have been running my 2 Voron 2.4, a 300 mm and a 350 mm, for a few years now with excellent results and minor updates/upgrades, like Klicky probe, Release 2 updates, part cooling 5015 fan, Nevermore filter and some cosmetic changes. It is also time to replace some plastic parts, deep clean and grease the linear rails, check belts and pulleys etc. The 300 mm Voron 2.4r2 (aka Voron-1) is running great for about five years now with the above upgrades and minor maintenance, so it was the first one to get an upgrade and maintenance. Stealthburner with LGX Lite v2; originally full size LGX. Reuse the Mosquito hotend with new heater and thermistor, and Convert from conventional cables to CAN network and finally go from Klicky probe to CNC Tap system. After rails serviced, new plastics printed and all the new parts for the Stealthburner, including LEDs, EBB etc. put together, the Voron-1 is back in service and working great! The CNC Tap system works great and love the simplicity of the CAN network; four cables! The cable chains look empty now! So it is time to service and update/upgrade the 350 mm Voron (aka Voron-2). But, I am not too happy with the part cooling performance of the Stealthburner, especialy try to print PLA fast, so I started researching other solutions. Of course, CPAP turbine and hose is the top contender for supplying part cooling air. Then I found the wonderful Github site of sneakytreesnake and his not Voron mainstream head CrownCooler. Unfortunately, is designed for Orbiter with a Rapido head. I have a Mosquito and a LGX Lite V2; so here we go to Fusion360! The existing projects I will be using are: CrownCooler (modified) Voron CPAP with muffler from Flaigenstool Engineering (modified for TPU gaskets) V2.4-Aire from @VoronManiac
