Showing results for tags 'hijax_pl'.
  • Other FDM Printers
    • Anet A8 / AM8
Found 3 results
  1. Version 2020.06.10
    8 downloads
    README Overview This is a mount for Creality Ender compatible controllers together with 40x40x10 fan to cool stepper drivers. Selection of compatible boards includes: Creality v1.1.5 (TMC2208) TH3D EZboard (TMC2208) SKR mini E3 v1.2 (TMC2209) and similar Print parameters as per Voron specifications: Layer height: 0.2 Infill: 50% or more Infill type: Grid Perimeters: 4 or more Top/Bottom solid layers: 5 or more Filament: ABS/ABS BOM 404010 fan 12 or 24V one (check controller board supply voltage) 4x M3 thermal thread inserts 4x M3 8mm screws 2x M5 BHCS 8mm T-Nuts
  2. Version 2021.03.21
    222 downloads
    README Overview This is a mount for 35mm DIN RAIL in legacy v2.2 way. Available in regular and angled version. Panel version (only angled) can be used to attach DIN rail to the back of Voron 2.4. Print parameters As per Voron specifications: Layer height: 0.2 Infill: 50% or more Infill type: Grid Perimeters: 4 or more Top/Bottom solid layers: 5 or more Filament: ABS/ABS
  3. Version 2020.06.10
    17 downloads
    README Overview This is a corner modification to alllow installing panels when some thoer way of extruction connection is used. Print parameters as per Voron specifications: Layer height: 0.2 Infill: 50% or more Infill type: Grid Perimeters: 4 or more Top/Bottom solid layers: 5 or more Filament: ABS/ABS
