Hello from NZ
Pierre52
Hello neighbour from Atearoa, and welcome to the forum. Sure someone will be able to advise on your project. Would be interesting to know a little more about yourself and if you feel like it, post a few sentences of introduction.
4 hours ago, Pierre52 said:
Unfortunately the existing 2020 is V Slot and the Rails are MGN 12
@Ducky4546 was able to modify some of the carriage pieces to fit MGN12 rails. I'm pretty sure they are the same between the Trident and the V2.4 gantry. Maybe he would be willing to share the files.
Also, the MGN12 rails are plenty wide enough to span V-slot 2020 profile so that shouldn't be a problem. The RatRig V-Minion uses MGN12 on V-slot profile as well. The flying gantry will just have a little more mass..
Welcome aboard! You will find there are definitely lots of friendly and helpful people on the forum.
I don't see that being an issue, it basically the setup on some of my printers, as @atrushing has pointed out there are mods for the MGN12 carriages out there.
It'll be fascinating to see a build diary of the conversion and follow along with it.
