- 0
Flob74
Hi everyone,
I integrated the SB2040 from Mellow Fly on my Stealthburner toolhead. Everything run just fine (I couldn't resist trying a print), but I can't use the on-board ADXL345 to run the klipper input shaper measure.
I got the following error :
I got an BTT Octopus and a Rapsberry PI 3B. The octopus works as a CAN bridge with the SB2040 and I flashed both bootloader with CANBoot. The Canbus was set at 500kbps.
The accelerometer seems online because I get datas with
ACCELEROMETER_QUERY
I run
TEST_RESONANCES AXIS=X on the console, the toolhead move, the frequency increase and at around 100Hz... mcu shutdown.
When I decrease the microsteps in the printer.cfg file, I can reach an higher frequency. For example, at 128 microsteps, I reach around 50Hz, and at 16 microsteps I reach around 100Hz.
Here are my thoughts:
If someone has already experience this before, or you have another ideas, thank you for your answer.
11 answers to this question
