z_tilt Help
khairi
Hi All,
Can anyone explain how to correctly configure the z-tilt?
It's hard for me to understand the Kliper document. https://www.klipper3d.org/Config_Reference.html
I even got more confuse watching the instructions from GoldenJaguar3D on YouTube.
It seems like I don't fully understand z_positions and points.
I am trying to setup z_tilt for an Ender 3 S1 Pro.
I tried adding the code below to my printer.cfg and I'm getting an error "z_tilt z_positions needs exactly 1 items".
[z_tilt]
z_positions: 235, 149.5
             44, 149.5
        44, 149.5
speed: 200
horizontal_move_z: 5
retries: 20
retry_tolerance: .0025
My understanding of the first line of the z_positions is X=235, Y=149.5 is to get my probe to the middle furthest right of my heat bed.
The number underneath that, X=44, Y=149.5 is to get back to close position of home middle of my heat bed.
I am pretty sure that is wrong.
By the way, I am a noob in 3D printing.
I have been searching the internet for days on the topic z_tilt but no luck.
That's why I'm asking for help.
I would appreciate anyone input on this.
It is all in the formatting. Once you have your points the format should look like this:
[z_tilt]
z_positions:                   ## This is at the beginning of the line, no indents, no tabs
         235, 149.5            ## This is a tab spaced from the beginning of the line or indented to the position of z_positions:
         44, 149.5.             ## This is a tab spaced from the beginning of the line or indented to the position of z_positions:
        235, 149.5.           ## This is a tab spaced from the beginning of the line or indented to the position of z_positions:
speed: 200
retries: 20
The above example indicate you have two Z-Steppers and these are the probing points. Hope this helps
Hi @khairi
Your z_position is the point of your two Z-Motors that control the pivot - this is where your bed is going to pivot, or correct itself when running Z_TILT_ADJUST.
The points are different values to the above - this is where you want to probe the bed in order to get it level. They are NOT the same values as the z-Position.
0,235        235,235
  |         Z0
  |         Z1
0,0.         235,0
(Assuming the bed size is 235x235)
Z0 is at 230,230
Z1 is at 230,25
  |      230,230
  |      230,25
0,0
These are your z-position.
Your probing points will be something like:
10,210
210,210
210,10
10,10
  |  1   2  |
  |  4    3 |
0,0
Your Z-Position should also be same as how you set up your Z-Motors. Z0 is the first, Z1 the second.
Hope this makes more sense
This is an example of an Ender 3 config, I found to help:
[z_tilt]
z_positions:
     377, 176
    -50,176
    320,176
    2,176
speed: 200
retries: 6
5 hours ago, mvdveer said:
Thanks for your help again, mvdveer.
I really appreciate you taking your time helping me out but it seems like I'm hopeless.
I'm guessing the pivot point mention on the document is talking about is my Y belt underneath my hot bed is the middle point?
I don't know which stepper motor is z0 and z1.
The more I read on z_tilt the more I get confuse and start guessing the X and Y position.
I tried and failed again.
I might just try to print and hope that the gantry isn't out of alignment.
I am still trying to decipher the Klipper document on z_postition and point.
Not that much information about a Creality Ender 3 s1 or the pro version on the z_tilt command.
At this point I don't need to understand what the document says but I have been trying to search for a printer.cfg file for an Ender 2 S1 pro that already has the position points.
4 minutes ago, khairi said:
Can you post your printer.cfg file and I'll have a look at it.
Could you also upload a picture of your printer please.
Z-Tilt is only in printers that has more than one Z Motor like the Voron 2.4, trident, etc. In my Voron 0 I don't have Z-Tilt
See:
https://klipper.discourse.group/t/ender-2-pro-configs/2337 which leads to:
https://github.com/spuder/klipper-ender2pro which has the following printer.cfg file
https://github.com/spuder/klipper-ender2pro/blob/main/printer.cfg
From what I can see, you probably do not need Z-Tilt as this config only has one Z-Motor.
You can delete that part of the configuration or comment it out with a # before each line. If you have a probe on the printer, You will use BED_MESH_CALIBRATE, SCREWS_TILT_CALCULATE or BED_SCREWS_ADJUST instead of Z_TILT
Hi mvdveer,
I have attached my printer.cfg file and some pictures of my printer.
I tried looking through those 3 config files but when I manually move my X and Y coordinate where the screw to adjust the bed is way off.
Either that or I don't really know what I am doing.
But if you don't think that I need z_tilt then I will move on with input shaper.
printer.cfg
Thank you for doing that. Had a look at the printer.cfg file and photos of the printer. Had a read on the specs of the Ender3pro(v1).
My observations:
You only have one stepper motor defined in your printer.cfg file:
The ender 3pro has two z-stepper motors but seems they are are both controlled by only one stepper driver as you have the original Creality board:
Z-Tilt WILL NOT work with this board, as you need two independent drivers for this to function. Each Z-Motor has to be connected to its own motor for the function to activate - that is why Klipper is complaining with an error.
You do not need z-tilt.
Let me know how you go and if there is anything else I can help with
8 minutes ago, khairi said:
Thank you for your help again.
Any time - that is what this forum is all about - helping and directing where we can. Please feel free to ask if you run into any problems at all. Feel free to ask - someone will always answer and try and help. Good luck with the printer and getting it tuned to perfection. It will be worth it all in the end.
