Asus Tinker Board R2.0 good alternative for Raspberry Pi?
Buurman
Anyone got experiences with this board and I wonder, it it a good alternative?
It got the right Display port, so you can still attach a touch LCD, I think.
I ordered one, but wonder if I did a good thing....
4 answers to this question
I wasn't even aware of it. Quick answer after a quick look is yes, I think it ought to work. The main things I'm looking at is it has the standard selection of USB and Ethernet plugs. The specs say a SIDI DSI, so the screen should interface. The 40-pin GPIO I would assume matches the Pi one. I would also assume it will run Linux, so should work. The devil is in the details: what tweaks need to be made to the Linux distro and Klipper/Moonraker to make them happy? That I can't answer.
I would second that. I like the fact it has a colour coded GPIO (counting pins is a PITA). I don't think you have made a mistake as it will work (runs debian 10, guess 11 as well) and the spec is definitely capable of what you need for a Voron/mainsail setup. I cannot imagine ASUS will be using some rinkdy-dinky home spun repo for the packages so I imagine you will have easy access to the entirity of the Debian pacage ecosystem.
I guess for me (being nosey) is "why"? Beyond the age old "cause I can", was there are reason that drew you to the TInkerboard? I know PI's are like Hen's teeth especially with @mvdveer trying to corner the global  market in them, but the Tinker Board doesn't look to be any cheaper - noting that could be perspective as I'm in bankrupt Britain and everything is going to be expensive (back to trading toilet paper) after our mini-budget and hourly Chancellor swap-outs.
No its absolutely not cheaper, so fo two reasons... ONE.. Im an curious idiot.. so I like to know if it works, TWO.. can get a Raspberry PI anywhere.
I still have 2, one original, one based on the computeboard of a pi4 on a BTT IO board, again, also curious if that works.
A Pi4 is now also prices around 80/120 euro for a 2/4Gb version with WIFI. Its stupid..
The Asus Tinkerboard is still more expensive, 130 or so, so NO, its not a long term solution, but it maybe be in case of emergency.
I currently build 1 to 2 Vorons a month, so I need some hardware 😛
I also like the colored GPIO pins, and overall its very good looking, antenna onboard for wifi, full hdmi port.. it seems good...
Edited by Buurman
I'm sure it will, but it is definitely good to try (and document 😉 )alternatives especially if they are generally applicable and not bespoke/technological-dead-ends.
I'd looked at some of those integrated klipper-MCU-Linux boards, I wasn't entirely convinced (beyond particular use cases) as you still needed a rare-as-hens-teeh PI CM and might fall into the "bespoke" category, not sure how standard those PI back-plane boards are, and they were limited in terms of options compared to a more traditional separate MCU/Computer combo.
I shall follow your investigations with interest.
