- 1
SamppaD
Hi. I rebuild my Voron 2.4R2 and after doing full electronics an motor swap wanted to move from Clicky probe RIP to Tap V2. Im running SB with galileo2 and clicky probe. Now installation of Tap v2 was easy and everything is working with good accuracy but i have a question regarding QGL. When homing tap will home to the center of the bed, as expected. When Tap is doing QGL it will complete the QGL and stay at right front corner of the bed, will not auto home after QGL is done. Now i would like it to return to home position X150 Y150 after QGL. Looking at the printer.cfg I cant find correct location to change this. What do i need to change in printer.cfg?
By the way noticed that if using galileo2 with this tap, X gantry chain will interfere with tap motion. Galileo 2, toolhead door bottom corner is really close to the Tap, so toolhead door need to be slightly modify, otherwise in use if the chain shifts slightly will trigger the tap and stop the printer.
Next mode still in transit Nitehawk..
3 answers to this question
