ABS layer adhesion
TitusADuxass
What is the main reason for bad layer adhesion with ABS.
My printers used to print lovely with ABS, now I have really bad layer adhesion.
I've tried:
Turning the print temp up and down.
Printing slower, printing faster.
Printing with more cooling, less cooling.
The only thing that I haven't done is dried the filament, is this likely to be the culprit?
I've tried:
Most likely Yes
1. Wet filament (moisture)
2. Too much cooling (need low cooling 20% or less)
3. Faulty spool (dud roll of filament)
4. Print temperature (Nozzle 260, Bed 110)
10 hours ago, mvdveer said:
Most likely Yes
I print with 265 nozzle & 105 bed.
I've had the filament spools in the oven at 50c for 6 hours, so we'll see if there's an improvement.
4 hours ago, TitusADuxass said:
Yes, cleaned and Nano Polymer applied.
no need of anything on a good pei sheet.
* print temperature : 255°/110° (ldo abs and extrudr asa)
* chamber temp : 45° minimum when print starts (at the end of the print T° is about 60° )
* if chamber is hot enough, no cooling for the 4 first layers, then 25% to 45% (depending on the toolhead used)
* pei whashed with hot water and dishwashing liquid (every time i put my dirty fingers on pei surface)
* z offset perfectly tuned
and all pieces should stay on pei without warping 🙂.
For additional context...
I'm printing ABS/ASA primarily on my VzBot. 240/110 with a minimum 20-minute soak to get the chamber around 40c ish.
I dry the sh!t out of my filament these days and am getting some of the strongest, best prints to date.
@TitusADuxass, I think drying or lack thereof is the underlying issue. It seems like it always is. Also, I used to print with ASA exclusively but now I have moved over to ABS because it just prints better for me.
Judging by the responses I think you're correct.
I'm now planning a actively heated filament cupboard using a very low wattage greenhouse heater and small controller that I have left over from my real ale brewing days.
I didn't mention this before... I run 10c cooler on my nozzle regardless of material because I use a Diamondback nozzle on everything. Running 250c for ABS with brass or steel, etc. would be the correct temp for those nozzles, give or take a few degrees to account for preference.
Interesting,  my problems started appearing after I changed to a hardened steel nozzle.
Thermal conductivity of the diamond tip is off the chart compared to the other materials. Steel being ~10% of diamond and ~1/2 of brass.
It probably wouldn't hurt to bump up the temp 5 degrees to compensate.
  • 4 months later...
I've had issues with ABS not sticking properly to PEI build plates, they have been properly cleaned both using warm water and dishwashing liquid followed up with 91-92% isopropanol wipe:
  • Textured PEI, bed 110 degrees, nozzle first layer 270 degrees then 255-260, chamber 50+ degrees, cooling fans low at 15% - bad adhesion and warping occur
  • Smooth PEI, bed 110 degrees, nozzle first layer 270 degrees then 255-260, chamber 50+ degrees, cooling fans low at 15% - bad adhesion and warping occur
  • Smooth PEI ligthly grinded with 800 grit water sanding, bed 110 degrees, nozzle first layer 270 degrees then 255-260, chamber 50+ degrees, cooling fans low at 15% - sticks to build plate like superglue to my fingers.
Grinding my smooth PEI plate to a matte finish did the trick for me, I don't need to use any glue, it sticks really good. Maybe even too good.
And of course the filament spools have been dryed according vendor recommendations.
Edited by 3Dfps240
For ABS & ASA Part Fan is 0% until layer 5. Encloser internal temperature 50 - 60 deg. C before start printing.
