- 1
DennisM
TL;DR: I hate this part of my build! I cannot get a working Z-stop that's reliable and it's frustrating as heck.
[rant]
I can't believe that the most difficult part of my 2.4r2 build is the stupid z-endstop! Some time ago I came across the sex bolt mod and though, that's a good idea, the pin can't fall out, right? So I bought that and printed the piece. Unfortunately, for some reason the pieces just didn't fit properly and I ended up ruining both the brass cylinder pieces and my PCB switch. So I bought another PCB switch and a pack of the brass cylinders from Amazon and tried printing the piece again. This time I scaled it to 101% trying to make things fit better. I should note that I have not had any other fit problems with the rest of my parts, so I don't want to blame my printer.
So this new piece seemed to work a bit better, but things kept sticking (press down and it wouldn't come back up), so I tried numerous things. I've gotten good at removing the stop from the bed now. In the middle of everything, I had an issue with the cable connector so I redid that and we were back in business as far as the connector & wiring.
I couldn't figure out what was sticking. I eventually thought it was the screw head inside the unit, so I shaved some plastic off the hole in the bottom to make more room. This seemed to help. So I put everything back together, and more than once (many times) everything seemed OK but once I installed the unit after a few minutes something would "settle" or whatever and the pin would stick again. I tried adding grease to the sexbolt but that didn't fix things. The common factor in this whole mess is the sexbolt itself, which I wonder if it's bent or something, not sure. I don't have another spare and I'm not buying another kit.
Eventually it seemed like I was good, things were working and I moved on to other stuff like the Z calibration, etc. thinking I was good.
During one of my first prints, however, I noticed the head moving past the Z stop and the euclid probe on the head getting too close for comfort. The magnets actually clicked on the Z stop, and it was just too close for my taste. So I thought, well, remove the Z stop and tighten the bolt some more to lower the sexbolt head. I measured what I was using and it was 2.5mm above the bed. I think that was too high.
Took everything apart, changed the M4 bolt to an 8mm (I had switched to a 12mm because it was too low before), added Loctite and then just kept turning, assembling, and measuring where I was with the bed height. Finally I thought I was good, so I finished it up and ran a Z home. The stop head was basically level to the bed, and that didn't work, it gave me an error because I think the bottom of the toolhead contacted the bed although I wasn't sure.
So I figured I needed to raise it a little, and that one thought turned into another hour of adjusting, installing, sticking, drilling out some more plastic inside, greasing, adjusting, sticking, etc. It was another frustrating time with the thing. Finally I thought I had things working after clearing out yet more plastic inside the unit, so I put it all back together and ran homing operating.
The head dropped down to the Z stop and when it moved back up the stop didn't close (got stuck again).
So I decided to stop, walk away, and come here to rant about it.
I should state that I tried the original probe many times but the rod was too long, and I wasn't ready to figure out how to cleanly cut it. Plus I thought, well it could fall out but how many of us turn our printers almost upside down? I may end up going with this route, but I'm not sure. Also, I went ahead and ordered the last "completely assembled" sexbolt z-stop assembly that Fabreeko had in an effort to make this problem go away.
[/rant]
If you made it this far, thanks for reading and maybe feeling my pain
Dennis
9 answers to this question
