Bed physical location offset from what it should be
DennisM
New build of a 2.4r2 300mm model. I used my slicer to slice a bed leveling model, and scaled it so it was fairly large, and the skirt ended up being close to the bed edges on the slicer (Prusa Slicer). Then I edited the gcode file and removed the model and left only the skirt, for speed and easy checking of the bed level in general.
The resulting print is offset from the bed and I'm wondering if there are settings in the printer.cfg that will help fix this. Some parameters:
  • You might initially say, "just move the bed back" but...
  • I moved the toolhead gantry as far back as I could, and set the hall effect end stop to call that "300" - you know, the end of the travel
  • I then moved the toolhead down and placed the z-endstop so that the nozzle would contact it properly.
  • I moved the bed to within 1-2 mm of the endstop
With those steps in mind, I don't think I can move it back any more because the nozzle just won't reach the z-endstop if that's the case.
So I'm hoping there are some parameters in the printer.cfg that I can edit instead.
Thanks!
Edited by DennisM
Added slicer screenshot
16 answers to this question
I think adjustments are done with a combination of these parameters:
#   Homing and Gantry Adjustment Routines
home_xy_position:267,350
##  Gantry Corners for 350mm Build
gantry_corners:
   -60,-10
   410,420
#   X/Y Stepper Settings
[stepper_x]
position_endstop: 345
position_max: 345
[stepper_y]
position_endstop: 350
position_max: 350
OK, discourd thinks that I need to modify position_min and position_max under the [stepper_y] section but it was unclear how. I guess I'll try shifting them 5mm to see what happens, not sure which way. I'll try something like min from 0 to 5, and max from 300 to 305.
Still open to suggestions if anyone knows for sure.
Here's what I am using now for the X, Y in printer.cfg:
##                  __
##    _____   _____/  |_  ___________  ______
##   /     \ /  _ \   __\/  _ \_  __ \/  ___/
##  |  Y Y  (  <_> )  | (  <_> )  | \/\___ \
##  |__|_|  /\____/|__|  \____/|__|  /____  >
##   X/Y Stepper Settings
##  B Stepper - Left
##  Connected to MOTOR_0
##  Endstop connected to DIAG_0
[stepper_x]
step_pin: PF13
dir_pin: PF12
enable_pin: !PF14
rotation_distance: 40
microsteps: 32
full_steps_per_rotation:200  # set to 400 for 0.9 degree stepper
endstop_pin: PG6
position_min: 0
position_endstop: 300   # for 300x300 build
position_max: 300       # for 300x300 build
homing_speed: 25        # Max 100
homing_retract_dist: 5
homing_positive_dir: true
[tmc2209 stepper_x]
uart_pin: PC4
interpolate: false
run_current: 0.7
sense_resistor: 0.110
stealthchop_threshold: 0
##  A Stepper - Right
##  Connected to MOTOR_1
##  Endstop connected to DIAG_1
[stepper_y]
step_pin: PG0
dir_pin: PG1
enable_pin: !PF15
microsteps: 32
full_steps_per_rotation:200  #set to 400 for 0.9 degree stepper
endstop_pin: PG9
position_min: 0
[tmc2209 stepper_y]
uart_pin: PD11
interpolate: false
run_current: 0.7
I would try this since you want the endstops further outside the print area, you will probably need to shift your Z probe coordinates up by 5 too
[stepper_x]
position_endstop: 305
position_max: 300
[stepper_y]
position_max: 300
I'm 75% sure on this one but it is what I'd try
Thanks, I don't think I'll touch the stepper_x since the left/right positioning is close enough for me.
But for the Y, I'll try what you suggested, and also make this change:
home_xy_position:204,300
to:
home_xy_position:204,305
I think that's what you are suggesting (?)
It worked! Here's what I ended up doing:
[stepper_y]
position_min: 0
position_endstop: 310   # for 300x300 build
position_max: 310       # for 300x300 build
And
[safe_z_home]
To:
[safe_z_home]
home_xy_position:204,310
And lastly I needed to update my autoz.cfg and euclid.cfg since the z-stop location changed, as well as the dock position relative to the x,y coordinates. I can still do some fine tuning, including shifting the X to the right a little but this method seems to work.
Thanks for the help!
can be the photo, but if you move your gantry to the front (free motors, and slowly move it, or better take off cables), do both sides touch at the same time? or is there space on one side?
Can be the photo that it looks like its off....
You mean check here to make sure gantry is square?
20220908_154857.thumb.jpg.38891519740093c1a23316abee675d01.jpg20220908_154903.thumb.jpg.b471ebe17ecd20b501885ab179210f3c.jpg
8 hours ago, DennisM said:
position_min: 0
did you have to put position_max to 310 for this to work? It's my understanding that this is effectively increasing the print capacity by 10
I first assumed I should be using 300x300, so I tried position_min: 10 but that didn't work out -- too many things were failing, so I changed it back.
But when I move the head to Y310 the nozzle is off the bed (basically over the z-stop) but at Y300 it's on the bed. So I think the 300x300 print area still applies for me.
yes, that was what I meant, since Dennis is asking multiple questions at ones and I looked at the picture, I coudnt help wondering if the basics are setup right...
I did check the squareness very carefully during my build, and also saw the video you mentioned some time ago. I'm good as far as the squareness of the gantry. I actually had verified all of this as well using a large framing angle tool as well, just to be sure.
That should be fine. For my Trident 250, my position_max for Y is 260, and the endstop pin is also defined at 260. That places the nozzle over the Z endstop pin perfectly. In the slicer, max size is set at 250, so it won't allow placing objects in that space behind the physical bed.
