- 0
DennisM
Let me clarify a bit. First of all, I just finished a 2.4r2 build so I'm very new to Klipper and what you can do with it.
Basically, here's what I have: klipper running on the Pi, Octopus MCU, Euclid probe, and Klipperscreen running on the Pi for the BTT TFT50 touchscreen display.
There's stuff I have to do each time I turn on the printer - home xyz, QGL, then CALIBRATE_Z. Then heat up the nozzle to load filament.
The above are all separate steps. Here's what I'd like to do:
I am not sure which z-home commands can be removed, and where they need to be. The main issues I have with the above:
I *think * I need to do the following:
So my main issue with the above is -- if I use the console and accidentally call CALIBRATE_Z before the probe is deployed, what happens? The switch on the probe end is wired NC like the other stops, so would CALIBRATE_Z stop right away because it thinks the probe is "triggered"? If so then I guess it doesn't matter if I accidentally run calibrate_z without the probe deployed. I could always just try it and get ready to stop the printer if it looks like it's going to try and take measurements without the probe attached.
Anyway, wordy post here but I wanted to try and be clear. Also I didn't address the auto pre-heating, but I don't think that's going to be hard to stick into the end of some macro.
6 answers to this question
