- 0
golddustpeak
After replacing the bearings in my (Voron 2.4 built this January) extruder a while ago I decided to look at the calibration again.
Starting with the suggested 22.6789511 I extruded about 85mm when trying for 100mm. I've slowly worked myself down to 17.5 and I seem to be stuck extruding 90mm of filament when trying for 100mm with little change between rotation_distance numbers tried.
Below is the segment from my printer.cfg file.
## Update value below when you perform extruder calibration
## If you ask for 100mm of filament, but in reality it is 98mm:
## rotation_distance = <previous_rotation_distance> * <actual_extrude_distance> / 100
## 22.6789511 is a good starting point
rotation_distance: 17.5 #Bondtech 5mm Drive Gears
## Update Gear Ratio depending on your Extruder Type
## Use 50:17 for Afterburner/Clockwork (BMG Gear Ratio)
## Use 80:20 for M4, M3.1
gear_ratio: 50:17 #BMG Gear Ratio
microsteps: 32
full_steps_per_rotation: 200 #200 for 1.8 degree, 400 for 0.9 degree
nozzle_diameter: 0.400
filament_diameter: 1.70
Any thoughts as to what is going on?
as always thanks for the help.
9 answers to this question
