Heat soaking and when is it ready
bdejong11129
I have been using this macro, which I modified from someone else's — https://github.com/Otann/voron_2_configs/blob/main/printer_data/config/features/heatsoak.cfg
You can set the time in minutes and bed temperature:
HEAT_SOAK DURATION_MIN=30
And when the time elapses I receive a notification on my phone, check the chamber temperature (once it happened that I forgot to close the door) and then start the print manually.
