Extra Neopixel LED string next to Stealthburner LEDs from Octopus 1.1 board
Just sharing in case it helps someone, can verify that it works.
I wanted to have strings of neopixel leds in the chamber, but already having 3 wires going from the board to the Stealthburner (by default) makes is hard to make a serial string of LEDS.
These are connected on the default controller (neopixel) PB0.
So I started looking for an alternative, on the board is a dedicated BLTouch 5 pin connector (right top) and I used this to power 60 leds (yes its a lot)
The pin I used is the PB06 and the 5V and GRD next to it on the same connector.
Just add the new string to your config (copy and make up a new name) and you are ready to go.
Printer.cfg
#### LED LIGHTS #####
[neopixel neo]
pin: PB0
chain_count: 4
#   The number of Neopixel chips that are "daisy chained" to the
#   provided pin. The default is 1 (which indicates only a single
#   Neopixel is connected to the pin).
color_order: GRBW
#   Set the pixel order required by the LED hardware. Options are GRB,
#   RGB, GRBW, or RGBW. The default is GRB.
initial_RED: 0.0
initial_GREEN: 0.0
initial_BLUE: 0.0
initial_WHITE: 0.0
#   Sets the initial LED color of the Neopixel. Each value should be
#   between 0.0 and 1.0. The WHITE option is only available on RGBW
#   LEDs. The default for each color is 0.
[neopixel chamber]
pin: PB6
chain_count:60
color_order: GRB
initial_RED: 0.0
initial_GREEN: 0.0
initial_BLUE: 0.0
Macro for turning them on/off: (and colors, and other freaky things, but I kept it simple for now)
[gcode_macro SB_LED_ON]
gcode:
  SET_LED LED=neo RED=1 GREEN=1 BLUE=1
[gcode_macro CHAMBER_LED_ON]
gcode:
  SET_LED LED=chamber RED=1 GREEN=1 BLUE=1
[gcode_macro SB_LED_OFF]
gcode:
  SET_LED LED=neo RED=0 GREEN=0 BLUE=0
[gcode_macro CHAMBER_LED_OFF]
gcode:
  SET_LED LED=chamber RED=0 GREEN=0 BLUE=0
Feel free to respond with freaky LED effects 😉
4 hours ago, claudermilk said:
Good tip. Anyway, ok you asked for it: https://github.com/claudermilk/TridentBackup/blob/aef1559d1ef62d692b05ef0560f34585de7e1da4/leds.cfg
I use the julianschill led_effects library (here: https://github.com/julianschill/klipper-led_effect).
First link isnt working for me, but yes, I know this one, pretty cool, but a bit too much disco for my printer..  but I like my startup sequence....
And going full blue as a color.. looks pretty cool if you ask me.. 😜
Well, I clearly don't understand how to share files from my Github.
So, let's just dump the file here. I'll hide it behind a spoiler since it's kind of long.
Spoiler
### Hardware definitions ###
[neopixel caselight]
pin: PB6
chain_count: 36
color_order: GRB
initial_RED: 0.0
initial_GREEN: 0.0
initial_BLUE: 0.5
[neopixel sb_leds]
pin: PB0
chain_count: 3
color_order: GRBW
initial_RED: 0.0
initial_GREEN: 0.0
initial_BLUE: 1.0
initial_WHITE: 0.0
### Effects Definitions ###
# Toolhead
[led_effect logo_busy]
leds:
	neopixel:sb_leds (1)
autostart: false
frame_rate: 24
layers:
	static 0 0 add (0.4,0.0,0.0,0.0)
[led_effect logo_calibrating_z]
leds:
autostart: false
frame_rate: 24
layers:
	static 0 0 add (0.8,0.0,0.35,0.0)
[led_effect logo_cleaning]
leds:
autostart: false
frame_rate: 24
layers:
	static 0 0 add (0.0,0.02,0.5,0.0)
#critical error, see below
[led_effect logo_heating]
leds:
autostart: false
frame_rate: 24
layers:
	static 0 0 top (0.3,0.18,0.0,0.0)
[led_effect logo_homing]
leds:
autostart: false
frame_rate: 24
layers:
	static 0 0 add (0.0,0.6,0.2,0.0)
#input-shaper
[led_effect logo_leveling]
leds:
autostart: false
frame_rate: 24
layers:
	static 0 0 add (0.5,0.1,0.4,0.0)
#loading?
[led_effect logo_meshing]
leds:
autostart: false
frame_rate: 24
layers:
	static 0 0 add (0.2,1.0,0.0,0.0)
[led_effect logo_party_time]
leds:
autostart: false
frame_rate: 24
layers:
    strobe 1 1.5 add (1.0,0.0,0.0,0.0),(1.0,1.0,0.0,0.0),(0.0,1.0,0.0,0.0),(0.0,1.0,1.0,0.0),(0.0,0.0,1.0,0.0),(1.0,0.0,1.0,0.0)
[led_effect logo_printing]
leds:
autostart: false
frame_rate: 24
layers:
	static 0 0 add (0.0,0.0,1.0,0.0)
[led_effect logo_standby]
leds:
autostart: false
frame_rate: 24
layers:
    breathing 12 1 add (0,0,1.0,0.0)
    static 0 0 add (0,0,0.05,0.0)
#unloading?
[led_effect logo_filament_runout]
leds:
autostart: false
frame_rate: 24
layers:
    breathing 6 1 top (1.0,,0.0,0.0,0.0)
[led_effect nozzle_heating]
leds:
	neopixel:sb_leds (2,3)
autostart: false
frame_rate: 24
layers:
	static 0 0 top (0.8,0.35,0.0,0.0)
[led_effect nozzle_off]
leds:
autostart: false
frame_rate: 24
layers:
	static 0 0 add (0.0,0.0,0.0,0.0)
[led_effect nozzle_on]
leds:
autostart: false
frame_rate: 24
layers:
	static 0 0 add (0.8,0.8,0.8,1.0)
[led_effect nozzle_party_time]
leds:
autostart: false
frame_rate: 24
layers:
[led_effect nozzle_standby]
leds:
autostart: false
frame_rate: 24
layers:
# Caselights
#busy ??
[led_effect case_calibrating_z_left]
leds:
    neopixel:caselight
autostart: false
frame_rate: 24
layers:
    comet 0.3 0.5 add (0.8,0.0,0.35),(0.4,0.0,0.7)
[led_effect case_calibrating_z_right]
leds:
    neopixel:caselight
autostart: false
frame_rate: 24
layers:
    comet -0.3 0.5 add (0.8,0.0,0.35),(0.4,0.0,0.7)
[led_effect case_cleaning]
leds:
    neopixel:caselight
autostart: false
frame_rate: 24
layers:
    twinkle 4 0.05 add (0.0,0.02,0.5)
    twinkle 2 0.1 add (0.0,0.06,0.2)
[led_effect case_heating_left]
leds:
    neopixel:caselight (1-18)
autostart: false
frame_rate: 24
heater: heater_bed
layers:
    heaterfire  10 0 top (0,0,0.1),(0.6,0.36,0)
[led_effect case_heating_right]
leds:
    neopixel:caselight (36,35,34,33,32,31,30,29,28,27,26,25,24,23,22,21,20,19)
autostart: false
frame_rate: 24
heater: heater_bed
layers:
[led_effect case_homing]
leds:
    neopixel:caselight
autostart: false
frame_rate: 24
layers:
    breathing 12 1 add (0.0,0.6,0.2),(0.0, 0.1, 0.03)
    chase 0.5 0.75 add (0.0,0.6,0.2),(0.0, 0.1, 0.2),(0.0,0.05,0.2)
[led_effect case_input_shaper]
leds:
    neopixel:caselight
autostart: false
frame_rate: 1
layers:
    static 0 0 top (0.25,0.0,0.5)
[led_effect case_leveling]
leds:
    neopixel:caselight
autostart: false
frame_rate: 24
layers:
    comet -0.75 1 top (0.5,0.1,0.4),(0.3,0.1,0.6),(0.1,0.1,0.8)
[led_effect case_loading_left]
leds:
autostart: false
frame_rate: 24
layers:
    chase 0.5 0.5 add (0.0,0.7,0.0),(0.0,0.35,0.05),(0.0,0.12,0.1)
[led_effect case_loading_right]
leds:
    neopixel:caselight (19-36)
autostart: false
frame_rate: 24
layers:
    chase -0.5 0.5 add (0.0,0.7,0.0),(0.0,0.35,0.05),(0.0,0.12,0.1)
[led_effect case_meshing]
leds:
    neopixel:caselight
autostart: false
frame_rate: 24
layers:
    chase 0.5 0.5 add (0.2,1.0,0.0),(0.1,0.5,0),(0.05,0.25,0)
    chase -0.25 0.5 add (0.2,1.0,0.0),(0.1,0.5,0),(0.05,0.25,0)
[led_effect case_off]
leds:
    neopixel:caselight
autostart: false
frame_rate: 1
layers:
  static 0 0 top (0,0,0)
[led_effect case_party_time]
leds:
    neopixel:caselight
autostart: false
frame_rate: 24
layers:
    strobe 1 1.5 add (1.0, 0.0, 0.0),(1.0,1.0,0.0),(0.0, 1.0, 0.0),(0.0,1.0,1.0),(0.0, 0.0, 1.0),(1.0,0.0,1.0)
    twinkle 5 0.05 add (1.0, 0.0, 0.0),(1.0,1.0,0.0),(0.0, 1.0, 0.0),(0.0,1.0,1.0),(0.0, 0.0, 1.0),(1.0,0.0,1.0)
[led_effect case_printing]
leds:
    neopixel:caselight
autostart: false
frame_rate: 24
layers:
    static 0 1 top (0.5,0.5,0.4)
[led_effect case_standby]
leds:
    neopixel:caselight
autostart:          true
frame_rate:         24
layers:
    breathing 12 1 add (0,0,1.0)
    static 0 0 add (0,0,0.05)
[led_effect case_unloading_left]
leds:
autostart: false
frame_rate: 24
layers:
    chase -0.5 0.5 add (0.7,0.0,0.0),(0.35,0.0,0.0),(0.13,0.05,0.0)
[led_effect case_unloading_right]
leds:
autostart: false
frame_rate: 24
layers:
    chase 0.5 0.5 add (0.7,0.0,0.0),(0.35,0.0,0.0),(0.13,0.05,0.0)
# Special Definitions
[led_effect critical_error]
leds:
    neopixel:sb_leds
    neopixel:caselight
autostart: false
frame_rate: 24
run_on_error: true
layers:
    strobe 1 1.5 add (1.0, 1.0,1.0)
    breathing 2 0 difference (0.95,0.0,0.0)
    static 1 0 top (1.0,0.0,0.0)
### LED Activation Macros ###
[gcode_macro led_busy]
gcode:
    STOP_LED_EFFECTS ;cancel all others
    SET_LED_EFFECT EFFECT=logo_busy
    SET_LED_EFFECT EFFECT=nozzle_on
    #SET_LED_EFFECT EFFECT=case_standby
[gcode_macro led_calibrating_z]
gcode:
    SET_LED_EFFECT EFFECT=logo_calibrating_z
    SET_LED_EFFECT EFFECT=case_calibrating_z_left
    SET_LED_EFFECT EFFECT=case_calibrating_z_right
[gcode_macro led_cleaning]
gcode:
    SET_LED_EFFECT EFFECT=logo_cleaning
    SET_LED_EFFECT EFFECT=case_cleaning
# Critical error
[gcode_macro led_blinkenlights]
gcode:
    SET_LED_EFFECT EFFECT=critical_error ; This activates all LEDs
[gcode_macro led_heating]
gcode:
    SET_LED_EFFECT EFFECT=logo_heating
    SET_LED_EFFECT EFFECT=nozzle_heating
    SET_LED_EFFECT EFFECT=case_heating_left
    SET_LED_EFFECT EFFECT=case_heating_right
[gcode_macro led_toolhead_heating]
gcode:
    SET_LED_EFFECT EFFECT=logo_cleaning STOP=1
    SET_LED_EFFECT EFFECT=logo_busy STOP=1
    SET_LED_EFFECT EFFECT=logo_standby STOP=1
    SET_LED_EFFECT EFFECT=nozzle_on STOP=1
    SET_LED_EFFECT EFFECT=nozzle_standby STOP=1
[gcode_macro led_homing]
gcode:
    SET_LED_EFFECT EFFECT=logo_homing
    SET_LED_EFFECT EFFECT=case_homing
[gcode_macro led_input_shaper]
gcode:
    SET_LED_EFFECT EFFECT=case_input_shaper
[gcode_macro led_leveling]
gcode:
    SET_LED_EFFECT EFFECT=logo_leveling
    SET_LED_EFFECT EFFECT=case_leveling
[gcode_macro led_loading]
gcode:
    SET_LED_EFFECT EFFECT=case_loading_left
    SET_LED_EFFECT EFFECT=case_loading_right
[gcode_macro led_meshing]
gcode:
    SET_LED_EFFECT EFFECT=logo_meshing
    SET_LED_EFFECT EFFECT=case_meshing
[gcode_macro led_case_off]
gcode:
    SET_LED_EFFECT EFFECT=case_off
[gcode_macro led_off]
gcode:
	 STOP_LED_EFFECTS
[gcode_macro led_party_time]
gcode:
    SET_LED_EFFECT EFFECT=logo_party_time
    SET_LED_EFFECT EFFECT=nozzle_party_time
    SET_LED_EFFECT EFFECT=case_party_time
[gcode_macro led_printing]
gcode:
    SET_LED_EFFECT EFFECT=logo_printing
    SET_LED_EFFECT EFFECT=case_printing
[gcode_macro led_standby]
gcode:
[gcode_macro led_unloading]
gcode:
    SET_LED_EFFECT EFFECT=case_unloading_left
    SET_LED_EFFECT EFFECT=case_unloading_right
[gcode_macro led_filament_runout]
gcode:
    SET_LED_EFFECT EFFECT=logo_filament_runout
On 5/26/2022 at 6:26 AM, claudermilk said:
Huh, let's try this one: https://github.com/claudermilk/TridentBackup/blob/master/leds.cfg
(ok, seems to be working)
Dang, those green parts are BRIGHT under the LEDs. 😎
Check your github profile. I suspect that the TridentBackup is private to your account. From an outside viewer, you only have two public folders and they are SmartThings related.
Edited by SteveThatcher
  • 3 months later...
Looking at the docs here: https://github.com/julianschill/klipper-led_effect/blob/master/docs/LED_Effect.md
I see this section that looks like it's what you are looking for:
Quote
Fading in and out
Effects can be faded in and out by specifying the FADETIME parameter: SET_LED_EFFECT EFFECT=panel_idle FADETIME=1.0 fades the effect in during one second. Running SET_LED_EFFECT EFFECT=panel_idle STOP=1 FADETIME=1.0 fades it out in one second. We can also fade out all effects by running STOP_LED_EFFECTS FADETIME=1.0. It is also possible to crossfade effects by running a fade in command and a fade out command successively.
  • 3 months later...
