"Pin 'gpio26' is not a valid pin name on mcu 'mcu' error message
Casatec
Hi, I am struggling with fixing the above mentioned error message.
Set-up: Voron 2.4, BTT Manta M8P + CB1 + EBB36 Can bus. I want to control a CPAP (external fan) via GPIO26 but i get an error.
In the printer.cfg I added:
[fan_generic CPAP]
pin: mcu:gpio26            #CPAP
max_power: 1
cycle_time: 0.002          # = 500 Hz
hardware_pwm: false   # as we use software pwm
shutdown_speed: 0       # dont run fan when klipper is not running.
I read that it might have to do with the [mcu] definition, however, i only see solutions for non CAN bus versions where a serial number can be added to the [mcu]. I also see some mentioning the GPIO definition when setting up klipper in the menuconfig but that didnt work either. I might be on the wrong path though. Any suggestion where to look? Attached my log and printer.cfg.
I also tried the following but no success:
pin: host:gpio26            #CPAP
pin: gpio26                 #CPAP
Thanks a lot! CS
printer.cfg.txt issue log.txt
