switchwire light diagonal movement x and z
nvanstaden
hi guys.
I have converted my cr10 style to a switch wire.
reason? takes up less space and just looks cool. good idea? maybe not.
so the problem I'm having is that on horizontal moves on the x, when travelling in the positive direction, it also descends by about 2mm per 100mm. in the negative its is the opposite.
on vertical moves (z) when travelling downwards, it moves right as well by 2m per 100mm and when travelling up it moves 2mm to the left per 100mm.
the belt meter shows a difference of belt tensions at o.o8mm (not quite sure how precise this need to be.
much appreciate.
