Raspberry PI 5 with Cooler / Cooling Fan
polygonprint
Hi All,
I recently swapped over to a Raspberry PI 5 from a PI 3B+ on my Voron Trident. Everything is up and running well. I purchased the PI 5 Active Cooler with the PI 5 and would like to have the fan on the cooler running all of the time when the printer is on. Currently it spins up briefly when the printer is booting up but then switches off. I'm still a bit of a newbie when it comes to setting up hardware, macros, etc.
Is there a way to have the fan on the PI run when the printer is on? How would I set that up in the printer.cfg ?
Temp's on the PI get up to the 40+ deg range when the printer is idle, however when the electronic housing fans kick in during printing the temp's are much lower on the PI. I probably don't need the cooler on the PI but think it would be nice to have it operational for the extra cooling when the printer is idle.
Thanks!
2 answers to this question
