- 0
DanPin
Just wanted to get some thoughts on this. Should be a fairly simple problem.
My Voron was working fine, then turned it off for a week. When I turned it back on, it gave a error msg during boot (Can't open acess point and authorization server)'
Flashed a new ssd (and tried 3 ssd's) using orig OS file and the latest rlease OS file from BBT, and the new symptom is:
1. Nothing shows when I ssh into the LAN port
2. When I connect via IP address, I get a screen that says moonraker can't connect to klipper.
I ordered a new Pi because I am thinking there is a basic problem with the SBC since the SSH does not work.
Are the odds good that the new Pi will fix it?? Did not really know what else to do since I can't xterm in.
Suggestions welcomed...
1 answer to this question
