- 0
gsezz
Hi,
I mostly finished my V0.1 LDO kit build, but I have some issues with the Z-axis. It seems the bed is too hard to lift for the motor, and I even stripped the T8 POM Nut.
Without the lead screw, the bed moves super easy on the linear rails. With the rails in a horizontal position, I can move the bed by blowing on it.
But with the default setting of run current = 0.37, the LDO motor isn't able to lift the bed against gravity. It's skipping steps, and the bed is even dropping down a little bit (screw turning backwards), while the motor struggles. Moving down works fine. Up works only when I help it a little bit with my finger. Turning the lead screw by hand, with the motor switched of, doesn't take an unreasonable amount of force either, I think.
Since the bed moves very easy without the lead screw, I think the screw must be the problem.
First I used a pretty stiff white lithium grease on the PTFE coated lead screw, but I couldn't get it moving upwards at all. Not even with a run current of up to 0.5. I didn't try more than that.
I read that a PTFE coated lead screws and POM nuts are intended to work without grease. So I removed the grease, and used some PTFE spray instead. With this I got it working reliably at a run current of 0.45.
After 30h of printing it stripped the threads of the POM Nut.
I changed the nut, even reprinted the part of the bed that holds it, tripple checked that the screw is straight, tripple checkt that the screw ist mounted parallel to the linear rails. I measured the distance from the rails to the screw at the bottom and top, which were the same. And also I mesured the distance at the top, while the bed was in the upper and lower most positions, which was consistent. So it seems there is no sideways pressure on the screw and Nut.
This time I used a softer all purpose grease, and got the same results as before with the PTFE-spray: Not able to move at run current of 0.37 at all, reliably at 0.45. This time the motor makes considerably more noise while holding. (btw I'm using a holding current of 0.35)
So, the printer is working now. But I still don't know if it stripped the nut only because I ran it without grease, or if something else is wrong. If there has been another problem, I gues I didn't solve it yet, because the motor still needs the same run current?
Is there any advice, besides just running the printer as it is and wait if it strips the nut again?
Since the provided printer.cfg (SKR Mini E3 V2.0) sets the run current to 0.37 for the LDO motor, I asume this should be enough? Is it ok to set it to 0.45? Stepper and driver aren't getting any warmer than the A & B ones.
7 answers to this question
