Connect Beacom
Andrea60
Hello everyone, I bought a LDO Nitehawk 36 Toolhead that turned out to be unusable, the goal was to use the USB port on board to connect the Beacon, LDO has announced that it will make a new version available in 3\4 months.... So I bought a Mellow SHT 36 V3 to use in rs232, the UTOR board is equipped with a hub with two USB ports. I would like your opinion: is it possible to connect the Beacom to one of the 2 ports on the UTOR board.
Unfortunately on the Raspberry PI4 having the adapter for m2 hdd, the Octopus Pro, the webcam and the UTOR I do not have space for the Beacom.
Thanks
If you're running out of USB ports use a USB Hub. I've used them with RPI on other projects with no issues. What were your problems with the NIghthawk? The over-temp shutdown issue? If not then you may want to look at it again. I'm still running my Nighthawk and beacon, with the beacon running to the USB port on the Nighthawk board. I didn't have to do anything special other than make sure I wired it up correctly. The wire colors are not a reliable way to determine the pinout. You'll have to compare both components' diagrams and ensure they are wired correctly.
Edit, after I looked up the Mellow SHT 36 V3, it says the two ports on the UTOR board can be used as rs232 to USB or USB extension. I read that is yes, you should be able to connect USB devices to it with no issues.
Edited by DocFoFo
Just buy a Pi USB hub. I added one to my RatRig for the same reason... Ran out of ports.
57 minutes ago, PFarm said:
Are you referring to a powered hub? I have a powered hub in both of my printers.
It could be a powered hub. The ones I have are just the little Pi hats connected with a USB cable.
I would assume that if you have it loaded with a lot of devices then powered would be better.
