Choosing a stepper motor
Cosmo
Hi,
I want to build a CNC plasma cutter but I have trouble choosing a suitable stepper motor, the gantry weight should be less than 25 kg, I have stepper drivers with phase current up to 6.0 amps, power supply +10 VDC to +50 VDC, industrial grade regulated power supply 48v, 10.4a
Which motor do you recommend me to use? Is this nema23 stepper motor ok? (https://www.oyostepper.com/goods-1198-Nema-23-Stepper-Motor-24Nm-33979ozin-4A-57x57x82mm-4-Wires-8mm-Shaft.html)
Thanks for your help.
