- 0
str0gg
Printer is dialed in for esun abs+ 0.4 nozzle and capable to print 25.5mm^3/s (orca slicer VFA test). Speed test velocity 900 and max acceleration 13000 no issue.
Current settings velocity 300 which reflex 24mm3 with headroom and max acceleration 9000.
Only useful log I was able to grep... (print first layer test nothing fancy circle 115 with layer 0.2 default slicer speed)
2024-09-03 20:55:30,725 [job_status.py:update_filename()] - Updating filename to Disc_ABS_4m46s.gcode 2024-09-03 20:55:30,725 [job_status.py:_update_file_metadata()] - Update Metadata. File: Disc_ABS_4m46s.gcode Size: 58785 2024-09-03 20:55:30,744 [screen.py:attach_panel()] - Current panel hierarchy: job_status > job_status 2024-09-03 20:55:30,751 [screen.py:show_panel()] - Reinitializing panel extrude 2024-09-03 20:55:30,772 [screen.py:attach_panel()] - Current panel hierarchy: job_status > job_status > extrude 2024-09-03 20:55:30,772 [KlippyWebsocket.py:gcode_script()] - Sending printer.gcode.script: SET_FILAMENT_SENSOR SENSOR=runout_sensor ENABLE=1 2024-09-03 20:56:47,583 [printer.py:change_state()] - Changing state from 'paused' to 'printing' 2024-09-03 20:56:47,583 [printer.py:change_state()] - Adding callback for state: printing 2024-09-03 20:56:47,593 [screen.py:set_screenblanking_timeout()] - Changing screen blanking to: 3600
I've also add gcode to confirm that its pausing issue.
[gcode_macro PAUSE] rename_existing: PAUSE_BASE gcode: M117 Paused LED_BED_CANCEL PAUSE_BASE
Does anyone have idea how to debug it further or fix it?
Extrude: LDO Orbiter v2
Hotend: Revo with diamond back nozzle 0.4
Toolhead: Dragon Burner v8
2 answers to this question
