Printer.CFG information and BTT Octopus V1.1 pinout for Camera, BLTouch and BTT Smart Filament Sensor
SMURPH
Can anyone send me the working information for the printer.cfg file and BTT Octopus 1.1 pinout for the following:
  1. Printer.cfg information and location in the file for a camera?
  2. Printer.cfg information and location in the file for the BLTouch?
    • Would it be better to use the BLTouch than the Inductive probe?
  3. Printer.cfg information and location in the file for the BTT Smart Filament Sensor?
    • BTT Octopus V1.1 pinout for the BTT Smart Filament Sensor?
1) For the camera, I would plug it into the PI.
3) My config is a mess of mods mashed together, but I can help with the BTT Smart detector. You can use any of the free stop pins. PG6, PG9, and PG10 are usually used up for for x, y, z end stops, leaving PG11 - PG15 free. I used PG11 for the smart detector.
##---   Filament Runout Sensor   ---##
[filament_motion_sensor btt_smartie]
detection_length: 7.0
extruder: extruder
switch_pin: !PG11
runout_gcode: FILAMENT_RUNOUT
gcode_macro M300]
  {% set S = params.S|default(1000)|int %}
  {% set P = params.P|default(100)|int %}
      SET_PIN PIN=BEEPER VALUE=0.5 CYCLE_TIME={ 1.0/S if S > 0 else 1 }
  G4 P{P}
[gcode_macro M600]
  {% set V = printer["gcode_macro _USER_VARIABLE"].verbose %}
  {% if V %}
    { action_respond_info("Filament Change Requested!") }
  {% endif %}
  SAVE_GCODE_STATE NAME=M600_state
  PAUSE
  G91
    G1 E-.8 F2700
    Park_Toolhead
  G91
    G1 E-15 F1000
    RESTORE_GCODE_STATE NAME=M600_state
[gcode_macro FILAMENT_RUNOUT]
  M300 S1 P10
  M600
  M300 S1 P10
extruder: extruder
switch_pin: !PG11
gcode_macro M300]
  G4 P{P}
[gcode_macro M600]
  {% if V %}
  {% endif %}
  PAUSE
  G91
    G1 E-.8 F2700
    Park_Toolhead
  G91
    G1 E-15 F1000
  M300 S1 P10
  M600
  M300 S1 P10
Thanks for the info. I will let you know how it goes tomorrow
Hi @JohnGalt1717 and welcome to teamFDM, I invite you to post a little something about yourself in the introductions section https://www.teamfdm.com/forums/forum/39-introductions/ or better yet, show us your baby in the build diaries section https://www.teamfdm.com/forums/forum/27-build-diaries/
Here is the Github for the 'Filament Please' MOD. I looked at it and I think you will find everything you need. The cfg is in the Klipper section.
https://github.com/VoronDesign/VoronUsers/tree/master/printer_mods/JD/RefillPlease
Cheers
