Voron 2.4 350mm with BBT Octopus V1.1, Hall Effect, and Z Probe printer.cfg issue
SMURPH
Just finished building my Voron 2.4 350mm with BBT Octopus V1.1, Hall Effect, and Z Probe. I went through the firmware install and preformed the X,Y,Z,Z1,Z2,and Z3 test but having issues with the printer.cfg doc. Does anyone have a working printer.cfg for a Voron 2.4 350mm with BBT Octopus V1.1, Hall Effect, and Z Probe?
Scott
Sure, this is for a V 2.4, BTT Octopus, hall effect x, y limit sensors. I connected bed probe using the method shown in the docs that requires a BAT85 diode.
A couple of non-standard things:
I used two ports for the controller fans rather than wiring them in parallel.
There is configuration for a BTT smart filament sensor in the encoder and macro sections of the file. I cannot vouch for this yet as I have not thoroughly tested it.
Use at your own risk.
printer.cfg
Thanks for the file but for some reason I am still getting errors. I am going to take all the connections off and try again. I will let you know what happens.
Option 'pin' is not valid in section 'board_pins'
12:31:33
Once the underlying issue is corrected, use the "RESTART"
command to reload the config and restart the host software.
Printer is halted
12:32:18
Restarting Klipper.
12:32:18
Klipper state: Disconnect
12:32:18
Klipper state: Ready
12:32:18
Klipper: Disconnected from host
12:32:39
Klipper: Connecting ...
12:32:39
Klipper: Connected to host
12:32:39
Connected to host via /tmp/printer @250000bps
12:32:39
Firmware version: 4c8d24a
12:32:59
Endstop x still triggered after retract
  • 11 months later...
