Milo V1.5 Build 2.2kw spindle water cooled
oggie
Did your spindle come with a cable to connect to the VFD or do you need to fabricate a cable? The first thing is to verify that your spindle is grounded to the spindle body. Use a multimeter to check the continuity of the ground pin to the body. Some Chinese spindles aren't grounded to the body. I'm looking forward to following your build.
ill take a look and yes it came with a ribbon cable if thats the one your referring to
