Dynaco ST-120 Tube Amplifier
I know this is way way off topic but there are a good number of parallels with building a 3D printer, at least from an electronics perspective.
This kit is available at Tubes4HiFi and can cost from $1200 US to $2K depending on what extras you add on. I got mine with basic tubes and I added Pentode-Triode switches and 2 matched pairs of NOS Russian paper in oil coupling caps.
Next up is chassis build and transformers.
...and a martini 😄
Lots of flipping the chassis over so I protected the transformers from getting scratched up with some bubble wrap.
Next up is wiring the Pentode-Triode switches. This will let me run the amp as either double ended (Class AB) or single ended (Class A).
Quad cap wiring.
Next up is the driver PCB.
And lastly, we test and set the bias for the output tubes.
All done... Sounds awesome!
On top is a Bottlehead tube preamp. It's been retired for a while now, but it was also a fun build.
Figured I'd throw a couple photos of the Bottlehead Foreplay III preamp as well.
47 minutes ago, claudermilk said:
BTW, gorgeous table that it's on in the first photo. Seems a shame to cover it with the electronics.
You're right about that. I need to get myself a replacement and put that table back in service. That table is from Syria and hand inlayed. It's a gaming table. The top rotates 90 degrees and you open it up.
Inside is an insert that has a chess board on one side and a felt mat for cards on the other.
If you take out the insert completely... There's a backgammon board.
And underneath the table is storage for all your gaming supplies.
Goes great with my Elephant (carved from soapstone)
Edited by Penatr8tor
Forgot something...
