- 0
I ran into an interesting problem whilst upgrading and maintaining a Trident 250mm build. (Build 10 January 2023 - VT.941)
Printer Configuration:
After doing all the maintenance and upgrades, the printer did not want to home. On homing either X or Y - the gantry moves in a diagonal manner. (It's not a crab - should not do this!)
On closer inspection and investigation, the A-Stepper (X- stepper, Left Hand Motor) "binds, freezes, locks" as soon as power is supplied to the printer. Even when the motors are disabled, the stepper does not move. Can move the gantry in the Y-axis, with the X-axis moving diagonally. But cannot move in the X-Axis at all! It is stuck, even trying to move it with force. And.... klipper does not complain. With the power off - movement in both X and Y is normal.
Upgrades and Maintenance as background:
Troubleshooting so far:
Conclusion from troubleshooting:
Is it software or hardware ?
If it is hardware, it would need to be the octopus board, but changing motor ports on the board, did not solve the problem.
If it is software, Klipper should complain - it does not.
Now my question - what the heck is going on?
8 answers to this question
