Backing up the Moonraker database (printing history, etc.)
DennisM
Any thoughts on this? When I recently had to rebuild my printer I was able to backup and restore my moonraker DB to migrate my printer's history, etc. to the new SD card / setup. Same printer so I wanted to preserve this data.
I was thinking, on the new system, I'd like to occasionally (either manually or automagically) backup the database by exporting the SQL into a file and then copying that to my NAS.
However, this command, which I thought is what I need to do, doesn't work on the new system:
root@mainsailos:/home/pi#  mdb_dump -f backup.txt -a .moonraker_database
mdb_env_open failed, error -30793 MDB_INVALID: File is not an LMDB file
And yes, I tried it as the `pi` user with the same results.
Any ideas what's going on?
Oops... figured this out. I had the old DB directory "~/.moonraker_database" from some previous work and that's not the right DB.
Trying from the correct directory yielded success:
pi@mainsailos:~/printer_data $ mdb_dump -f backup.txt -a database/
drwxr-xr-x 11 pi pi    4096 Feb 25 10:29 .
drwxr-xr-x 23 pi pi    4096 Feb 10 15:29 ..
drwxr-xr-x  5 pi pi    4096 Feb 10 15:33 backup
-rw-r--r--  1 pi pi 1070153 Feb 25 10:29 backup.txt  <-- new backup file
drwxr-xr-x  2 pi pi    4096 Jun 18  2023 certs
drwxr-xr-x  2 pi pi    4096 Feb 23 11:41 comms
drwxr-xr-x  2 pi pi    4096 Feb 14 08:24 config
drwxr-xr-x  2 pi pi    4096 Feb 10 15:59 database
drwxr-xr-x  6 pi pi    4096 Feb 23 08:42 gcodes
drwxr-xr-x  2 pi pi    4096 Feb 25 09:22 logs
drwxr-xr-x  2 pi pi    4096 Feb 10 12:26 misc
-rw-r--r--  1 pi pi     131 Jun 18  2023 moonraker.asvc
-rw-r--r--  1 pi pi     115 Feb 10 12:46 moonraker_secrets
-rw-r--r--  1 pi pi      32 Jun 18  2023 .moonraker.uuid
drwxr-xr-x  2 pi pi    4096 Jan 20 11:17 systemd
pi@mainsailos:~/printer_data $ pwd
/home/pi/printer_data
