MMB CAN V1.0
McCosch
Hello, I would like to connect the MMB CAN V1.0 to the BIGTREETECH Octopus Pro. The cable supplied should be connected to the Octobus board, unfortunately I can't find the connector for the CAN-L cable. According to various drawings and pictures on the Internet, the place where the CAN-L is marked is the LAN connection for the BIGTREETECH Octopus Pro. Can someone help me there .
Edited by McCosch
The RJ11 jack on the octopus board is the can connection. However - you will need to flash the octopus board with the canbus software to enable USB -Can bridge.
I assume you have already flashed the MMB board.
Start with installing katapult
Then install katapult for octopus
cd ~/katapult
make menuconfig
and compile it
make
Set the octopus in DFU mode by applying the jumper from the 5V (blue area) to the boot pin (purple area)  as shown and pressing the reset button (green area) once after power up.
enter
lsusb
and you should see the board in dfu mode. then issue the following command to get the boards address:
dfu-util -l
You should see a line stating the internal flash address of 0x08000000 and the USB address of 0483:df11
sudo dfu-util -a 0 -D ~/katapult/katapult.bin --dfuse-address 0x08000000:force:mass-erase:leave -d 0483:df11
Remove the boot jumper and restart the board.
Set up your can network:
Add the following to the newly created file
allow-hotplug can0
iface can0 can static
  bitrate 1000000
  up ifconfig $IFACE txqueuelen 1024
Save and exit the editor.
Time to flash klipper with can to the octopus board:
cd ~/klipper
make menuconfig
and compile it
make
Flash the firmware to the octopus board by obtaining your boards serial. Issue the following command.
ls -al /dev/serial/by-id
Note the serial and copy it
cd ~/katapult/scripts
pip3 install pyserial
python3 flash_can.py -f ~/klipper/out/klipper.bin -d /dev/serial/by-id/{insert your serial here}
Reboot the board and you should be up and running.
That is correct. You will need to make up a connection to the supplied cable by either utilising and old telephone cable,
or crimping on a RJ11 jack
or using an adapter.
Connect the CanH and CanL to the two middle pins of either solution..
Connect the 24V power cords to your 24V power source.
I have also linked to a post in this forum explaining it in a bit more detail, and a manual you can download.
Hope this helps
cd ~/katapult
make menuconfig
and compile it
make
enter
lsusb
dfu-util -l
allow-hotplug can0
  bitrate 1000000
cd ~/klipper
make menuconfig
and compile it
make
Hope this helps
thank you very much for the detailed explanation. Unfortunately the board doesn't fit, I have a different one and the slot that you marked in red is missing. I'll send you a picture of my circuit board.
You have an Octopus pro board. I have marked the location of the boot jumper for your board
20240131_1424241.thumb.jpg.3eb4d783598ca99092a109e3d5871cac.jpg.1bc1b72973cd2c8d128dc952fd25160b.jpg.
Just remember, if you are going to flash the board as described above, you will need to unplug all cables.
  • 3 months later...
cd ~/katapult
make menuconfig
and compile it
make
enter
lsusb
dfu-util -l
allow-hotplug can0
  bitrate 1000000
cd ~/klipper
make menuconfig
and compile it
make
Hope this helps
This was immensely helpful, thank you.
Note to others, you need to disconnect *everything* from the MMU board to get it to boot into DFU mode.
Similarly, did not expect the Octopus to require 24v to be connected for it to boot into DFU
Minor edit to the Octopus DFU Flash directory as it defaults to "/out" and was giving me an error
sudo dfu-util -a 0 -D ~/katapult/out/katapult.bin --dfuse-address 0x08000000:force:mass-erase:leave -d 0483:df11
UPDATE - follow the link shared at the bottom of the howto above! Extremely well documented, its for a different CAN device but helped me get my Octopus updated to CAN and explained through how to get the new ID and update the [mcu] mapping in printer.cfg. mvdveer is a wizard 🙂
Edited by ianryeng
added details and pointer to follow the link
