Bed heating
Pappy3831
After a long hiatus I’m back to building my 2.4. In the process, I ordered an LDO 250 trident kit. I’m a glutton for punishment. And I’ve watched too many build videos.
back to the subject.  Thinking of getting the mandala ultra flat bed for the 2.4. The question is does getting a heater that goes almost edge to edge be beneficial to a more even bed plate heating?
Always will be. Also cuts of time in soaking the bed to allow for thermal expansion.
According to the Voron Team, power should be limited to 0.4W/cm². Has to do with warping.
This is something I don't understand... Shouldn't it be calculated from a volume ?
As a result, the max PWM has to be limited in Klipper. Same with the 0.2. 60% ; takes too long to heat up, set it to 80%, no problems sor far.
"Stock" Voron 2.4 bed is 8mm thick. LDO one is 10mm thick. 25% more. Just verrified.
Here's a calculator :
https://tools.takuya.wtf/Calculator.html
Also read on Voron forum or Reddit that this rule of thumb is obsolete, but no explanations...
Some thoughts ?
(we even could imagine something progessive ; progressively delivering more and more power, depending on the temperature)
