Not a Voron - VZBot resurrection
6 hours ago, mvdveer said:
I was also told on discord that I had a lot of red flags for a VZBot:
1. Octopus Pro v1.1 - bad board
2. SHT36v2 - voltage problems
3. EVA3 toolhead - outdated - apparently 2.4 is better
4. Rapido hotend - will fail
Ah well, too late now - lets see how it performs with the red flags
(Not really worried - more a tongue in the cheek post)
And I am sure the justification for those comments were "for reasons... trust me..." ROFL
Tuning going well, just need to tweak first layer and pressure advance a bit more. Next is panels, RCS fans and topcoat fitment. Cooling needs to be improved at the speed it is printing, thus will go CPAP ( @cjkennedy72 might be something you want to consider from the start) Printing the parts now.
Speed Test:
Printing
Pretty happy at this stage.
@mvdveer
I just wanted to alert you to an issue I just experienced. On the VzBoT CNC toolhead... the CPAP fan duct has 4 mounting points... two at the rear and another two where you screw 2 M3 SHCS' up from the underside and into the bottom of the toolhead.
You will want to loctite those two screws because if they should happen to vibrate loose... Gravity will drop them onto your part, while it's printing. Don't ask me how I know. 😄 Fortunately I caught it soon enough that I could recover. No damage and no need for new parts.
These two screws (red arrows)
CNC carriage arriving today - thanks for the heads up - just in time! Also going Carbon Fibre for X- Rail. Just a bit concerned about distortion when chamber gets hot. (Apparently this can happen if chamber temp gets above 60C
Update:
RSCS fans installed and panels fixed. Have ordered some 3mm plexiglass to cut new panels and doors as the ones on the printer got damaged whilst it was in storage.
Was going to convert this to CNC parts but decided it would be more fun to build an all metal VZBot. Thus, the parts already ordered will go towards that project - VZBot 235 all aluminium AWD.  (Self-Sourced, not a kit. (Five out of eight of my Vorons were all self -sourced - Voron2.4r2, Voron Switchwire, Voron 0, voron Trizero, Voron Boxzero, so why not a VZBot)
Will be fitting the tophat tonight after work and put the printer into "production" .
Whilst I enjoyed this build it was extremely frustrating due to a variety of reasons:
1. Lack of adequate instructions/manual
2. unsynchronised stepper motors.
3. The struggle with Octopus Pro and SPI drivers
4. The EVA3D v3 toolhead and the "space" it takes up. (Looses 30mm of Y travel)
5. Squaring the frame - this printer originated from a Tronxy X5SA and the extrusions are not the best there is.
Just to name a few........
Will post a photo of the printer when tophat is fitted and then close this thread.
Welcome to the family VZ.254
Glad this saga came to an end. However the printer is printing really well, and fast.
Build formally finished.
Thanks to all for your help and advice
I am in the process of building a  v2.4 or a V2.4/ VZbot mutant. Did you ever have luck with the 5160 pros? Did the commenters on discord why the Octopus Pro 1.1 is considered a bad board? I was about to pull the trigger on ordering both. Thank you in advance.
My VZBot 330 runs on an Octopus Pro board with 48V 5160 drivers. As a matter of fact all my printers are running Octopus boards. Have not had a problem on any. With the 5160 drivers it is important to note the wiring to the drivers as this is cause for the most issues I had. You will also need to connect the two power supplies via GND in order for the 5160 to operate. I am currently in the process of converting a Ender Plus to an AWD Mercury One with a 5 toolhead Lineux Toolchanger and this will run on an Octopus board with 48V 5160 drivers.
5 hours ago, SBeck said:
Great, thank you. I enjoyed reading your post, very informative. Are you running 6160T, 5160 Pro, or external 5160Plus drivers?
I initially had the very first released external 5160 Pro drivers but as I found them to bulky, I switched to the 5160T Pro drivers.
6 hours ago, SBeck said:
Thank you. Meaning ground the power supplies together? In industrial electrical this is something we do with all DC power supplies in order to prevent feedback issues.
The supplies already share a common earth ground. What needs to be specifically shared between the two PSU's is a single wire between the NEUTRAL leads on each unit. I had to add that in order for the PSU to output 48v to the 5160 modules.
