- 0
sisyphus
Voron 0.2 Z woes
I have got x and y working perfectly with sensorless homing.
Z also works perfectly.
My problem is I am not able to get the bed at proper print height.
Starts printing when Z is at 30. whereas is should be at 119.11.
Here are the relevant (I think) configs.
# Z STEPPER SETTINGS
[stepper_z]
step_pin: gpio19
dir_pin: gpio28 # Remove the ! before gpio28 if motor direction is inverted.
enable_pin: !gpio2
rotation_distance: 8 # For T8x8 integrated lead screw
microsteps: 16
endstop_pin: ^gpio25
position_endstop:0
position_max: 119.11
position_min: -5.0
homing_speed: 10
second_homing_speed: 3.0
homing_retract_dist: 3.0
#homing_positive_dir: false
# Z TMC2209 SETTINGS
[tmc2209 stepper_z]
uart_pin: gpio9
tx_pin: gpio8
uart_address: 1
interpolate: False
run_current: 0.37
sense_resistor: 0.110
stealthchop_threshold: 1
# HOME Z
[gcode_macro _HOME_Z]
G90
G28 Z
G1 Z30 F1800
# HOMING OVERRIDE
[idle_timeout]
timeout: 1800
[homing_override]
axes: xyz
set_position_z: 0
G90
G0 Z-5 F1200
{% set home_all = 'X' not in params and 'Y' not in params and 'Z' not in params %}
{% if home_all or 'X' in params %}
_HOME_X
{% endif %}
{% if home_all or 'Y' in params %}
_HOME_Y
{% endif %}
{% if home_all or 'Z' in params %}
_HOME_Z
{% endif %}
Edited by sisyphustypo errors
0 answers to this question
