Question regarding TAP and Can Bus
pfm
Hi, I'm upgrading to Tap and Can Bus.  I'm at the stage where I'm updating my Klipper config.  When I save printer.cfg and restart I get an error that say:
"Option 'z_offset' in section 'probe' must be specified".
Here is my Probe section:
#   Probe
[probe]
[output_pin PB5]
pin: Can0: PB5
x_offset: 0
#y_offset: 19.75
y_offset: 0
#z_offset: 6.42
z_offset: 0
speed: 5
samples:3
samples_result: median
sample_retract_dist: 2.0
samples_tolerance: 0.01
samples_tolerance_retries: 3
activate_gcode:
    {% set PROBE_TEMP = 150 %}
    {% set MAX_TEMP = PROBE_TEMP + 5 %}
@@ -29,4 +40,5 @@ activate_gcode:
            TEMPERATURE_WAIT SENSOR=extruder MAXIMUM={ MAX_TEMP }
        {% endif %}
    {% endif %}
#*# [heater_bed]
#*# control = pid
#*# pid_kp = 41.970
#*# pid_ki = 1.546
#*# pid_kd = 284.871
#*# [extruder]
#*# control = pid
#*# pid_kp = 31.663
#*# pid_ki = 3.909
#*# pid_kd = 64.117
Am I doing something wrong? I've tried manually adding a value for z_offset in the DO NOT EDIT BELOW area, but this does not resolve the issue.
9 hours ago, pfm said:
[probe]
[output_pin PB5]
Take out the brackets from [output_pin] - should just be
output_pin: PB5
What is happening is that klipper sees nothing under [probe] and reads the z-offset as a function of [output_pin]
