Still can't get my TAP with Can to work.
mbunjes
Set up : Octopus v1, SB2040 v2, Optotap v1. Canboot and Canbus installed, no errors.
I first had the Optotap v2.4.1 connected to gpio25, gnd on the front connector and 5V from the endstop connector on the SB2040. I had soldered the solder bridge on the Optotap for 5V.
The leds on the octotap worked but ENDSTOP_QUERY did not report a working endstop.
I then aquired a octotap v1, connected it the same way : no leds and no z endstop. Connecting all the wires to the 5V endstop connector and gpio28 : no endstop.
I'm out of ideas, what could the issue be ?
Decided to test Optotap with external power supply : LED llt up red when I interrupted the op0tical switch. Isn't it supposed to turn blue when it's not triggered ?
Edited by mbunjes
9 hours ago, mbunjes said:
BTW the Optotap v1 did not work.
Just installed a SB2040 Canbus on the Sitchwire revival build, (Octopus v1.1 with CanBoot).
Converted to TAP and used the V1 Optotap PCB, connected to 5V port (gpio28) - no issues at all - worked first time.
No soldering, no bridging. As I understand it, the Optotap v1 had no issues when connected to 5V, only to 24V. My experience in 4 installs now.
11 hours ago, mbunjes said:
Is this working on the Switchwire or do you have a y axis conversion that makes the bed more rigid ?
Had to make the bed more rigid by adding two additional Y-Rails. TAP is working with very low variances in the corners.
As time is a factor, I have not yet fully tested, just some quick preliminary tests.
Will keep you updated.
18 hours ago, mbunjes said:
Does this still use the Prusa Y axis carriage ?
The build I am doing it does. Have seen variations on discord where 4-6mm alumnus plates have been used. @Penatr8tor suggested stiffening the corners of the bed, which I will do with a solid square aluminium, replacing the spacers.
  • 4 weeks later...
