SB2040 impossible connection
On the SB2040 v2 the 24V connector is so close to the 8 pin connector that when a connector is plugged in the Stealthburner can't be fitted anymore. I'm forced to use the 5V connector instead.
I just received my tap-pcb v2.4.1. Am I correct in assuming I'll have to solder two of the tabs together to get either 24 or 5V ?
