Klipper - Filament Unload / Pause / M600 Macros
Wick
today I found the mainsail-config when searching why I can't edit the mainsail.cfg.....
as there is also a M600 i tried to modfy my unload Filament macro to work together with the PAUSE from there, they use the 'printer.extruder.can_extrude' to check if the hotend temp is high enough to extrude. as I need it the other way around to heat up if required I thought I could use this instead
{% set hotendtemp = params.HOTEND|default(230)|int %}
{% if printer.extruder.temperature < '210' %}
      M117 Heating...
      STATUS_HEATING
      M109 S{hotendtemp}
{% endif %}
so my M600 is only
[gcode_macro M600]
description: Filament change
    PAUSE Z_MIN=50
    UNLOAD_FILAMENT
to work during colour change while the UNLOAD_FILAMENT macro should work alone as well....
[gcode_macro UNLOAD_FILAMENT]
despription:Filament Unload
    SAVE_GCODE_STATE NAME=unload_state
#    M104 S{hotendtemp}                                                          ; set & continue hotend temp, default to 230 -> deactivated for test M600
    {% if printer.toolhead.homed_axes != 'xyz' %}                               ; Home if not already homed
      M117 Homing...
      STATUS_HOMING
      G28        ; Alphaville: Lassie come home, come home lalala
    {% endif %}
    {% if printer.extruder.temperature < '200' %}                               ; too cold? seems no active print so no M600 then ...
      G1 Y50 X300 Z50 F3600                                                     ; move toolhead to reachable position and ...
      M117 Heating...                                                           ; heat up
      STATUS_HEATING
      M109 S{hotendtemp}                                                        ; set & wait for hotend temp, default to 230
    {% endif %}
    G91
    G92 E0        ; reset Extruder
    M117 Unloading Filament
    STATUS_PRINTING
    G0 E10 F360        ; extract a bit
    G0 E5 F3600        ; blob a bit
    G0 E-22 F3600                                                               ; forming filament Tip for Rapido -> from ERCF V3 ercf_software.cfg
    G0 E2 F300
    G0 E-2.1 F300
    G0 E2 F300
    G0 E-2.2 F300
    G0 E2 F300
    G0 E-2.3 F300
    G0 E2 F300
    G0 E-2.4 F300
    G0 E2 F300
    G0 E-2.5 F300
    G0 E2 F300
    G0 E-43 F300        ; Filament Tip cooldown till extruder gears for Rapido -> from ERCF V3 ercf_software.cfg
    G0 E-100 F3600                                                               ; aaand puke it out fast
    M117 Filament unloaded!
#    STATUS_COOLING                                                               ;-> deactivated for test M600/PAUSE
#    TURN_OFF_HEATERS                                                             ;-> deactivated for test M600/PAUSE
    G90
#    G0 X300 Y360 F3600                                                           ; park nozzle over bucket -> deactivated for test M600/PAUSE
    STATUS_READY
    RESTORE_GCODE_STATE NAME=unload_state
So my question to the Macro Gurus, do you think this could work or do you have better ideas (as sometimes little Wick thinks the world is a lollipop🙈)?
Edited by Wick
  • Wick changed the title to Klipper - Filament Unload / Pause / M600 Macros
hahaaaa, got it....
if you are crazy enough to try out my weird thoughts you need to have customisable mainsail-configs installed ( to have different park positions for Pause/Cancel/Retractions etc, very useful! )
I modified my unload/load macros to include the colour change.
So if you define a colour change in your slicer, and printing comes to the layer with colour change, toolhead goes to the defined position and unloads the filament, when inserting the new colour, simply push   load filament   button, fila will be loaded and print resumes automatically. standard load/unload works as before..
description:Unload Filament
    {% if printer.pause_resume.is_paused == False %}                            ; PAUSE active? if not then normal unload with position, heatup, and tip...
        M117 Homing...
        STATUS_HOMING                                                           ; LEDs show homing
      {% endif %}
      M117 Heating
      STATUS_HEATING                                                            ; LEDs show heating
      STATUS_PRINTING                                                           ; LEDs show printing
      G91
      G0 E2 F300
      G0 E-2.1 F300
      G0 E2 F300
      G0 E-2.2 F300
      G0 E2 F300
      G0 E-2.3 F300
      G0 E2 F300
      G0 E-2.4 F300
      G0 E2 F300
      G0 E-2.5 F300
      G0 E2 F300
       M117 Fila unloaded, what now?
    {% else %}        ; UUPS!! Pause or M600 active, hurry up now, time is Filament
      G91
      G0 E-150 F3600                                                             ; schwupdiwup, away with it
      M117 Fila unloaded, hurry up for the next!
    {% endif %}
#    STATUS_COOLING                                                               ; LEDs show cooling
#    TURN_OFF_HEATERS                                                             ; cooldown
    G90
    STATUS_READY        ; LEDs show ready
[gcode_macro LOAD_FILAMENT]
description:Load Filament
    SAVE_GCODE_STATE NAME=load_state
    {% if printer.pause_resume.is_paused == False %}                            ; PAUSE active? if not then normal loading with position, heatup...
        M117 Homing...
        G28        ; Lynyrd Skynyrd: sweet home Alabama Lalala
      {% endif %}
      M117 Heating
      M117 loading Filament
      G91
      G1 E200 F360                                                              ; extract 200mm for colour change
      G1 E5 F3600                                                               ; blob for cleaning Nozzle
      G1 E-10 F1200                                                             ; retract for non oozing
      M117 Filament ready...
#      TURN_OFF_HEATERS
      G90
      STATUS_READY                                                              ; LEDs show Ready
      RESTORE_GCODE_STATE NAME=load_state
    {% else %}        ; UUPS!! Pause or M600 active, hurry up now, printfailure waits for you
      G91
      G1 E-1 F1200                                                              ; retract for non oozing
      M117 Filament ready, resuming...
      G90
      RESUME
    {% endif %}
[gcode_macro M600]
    PAUSE Z_MIN=50
    UNLOAD_FILAMENT
Edited by Wick
Wasn't even aware of that. Definitely will have a read of it though. Thanks.
As you put out a challenge....
What me crazy? What you talking about? Crazy
I might even try it.
      {% endif %}
the 2 G1  needs to be modfied for your printersize (mine is for 350)
and also the 2 unloading parts with the values for your hotend as stated ercf_software.cfg (which I wouldn't have found without your ERCF Thread 😉) for forming a tip when unloading
changed a little bit..... so now no longer neccessary to change Park positions or rectractions on Pause or Cancel in the unload and load sections, these values are now taken from the predefined Variables of the customisable mainsail-configs and some other changes, tested and works fine for me, now I just need to find out how to change to the extrude menu of klipperscreen on pausing when colour change, found no way so far, anyone with an Idea ?
I placed it in the Printer.cfg macros section before print_start and print_end
Unload_load_M600.cfg
