Automated Klipper MCU updates
Wick
until now updating the klipper MCU was a bit boring to me with the Octopus.... make menuconfig, make, getting the .bin with WinSCP, copying the .bin to sdcard on PC, inserting the SDcard to the octopus, Powercycle.....
Now I found this Guide from Drachenkatze that uses the already in Klipper included flash-sdcard.sh script to automate the updates on one ore more MCU's without having to run around with the sdcard to get the updates to the mcu's. I tried it and it works great👍
I wonder who already uses this as this was new to me?
I saw the guide and use this, here is my script for a BTT Octopus 1.1:
sudo service klipper stop
cd ~/klipper
git pull
make clean KCONFIG_CONFIG=config.octopus
make menuconfig KCONFIG_CONFIG=config.octopus
make KCONFIG_CONFIG=config.octopus
./scripts/flash-sdcard.sh /dev/ttyACM0 btt-octopus-f446-v1.1
sudo service klipper start
Wasn't aware of this either - thanks for sharing - will come in very handy
I have a BTT Octopus 1.1 and when I originally brought my printer online I used this.
It worked great!
However, it stopped working for me a couple of months back, and that sucks.  I haven't worked on getting it to work again, my guess is that I put a USB hub in the works, and the connection to the Octopus goes through that.  I'm guessing that's the issue, but I've got other things I'm working on at the moment.
I can say that I still update my Fly SB2040 and RPi this way though and it works great!
Guys, take a look at RatOS, they have macros for compiling the firmware from Mainsail/Fluidd UI. So you don't even have to use SSH or something.
With a proper bootloader like CANboot which is not only useful for CAN and also supports flashing over USB also that fiddling with SDcards is not necessary anymore.
hmm think I found something about here
after installing the G-Code Shell Command Extension it shouldn't be a problem to start the MCU-updates automatically when updating klipper in mainsail like the way it's done here with automated shutdown with tasmota
