Post Processing Scripts
WillyM
I would like to disable my filament run out and motion sensors for certain prints. My sensor is remote from the toolhead and I would like to directly feed filament to the toolhead on occasion. If I insert the necessary disable scripts as Prusaslicer post processing scripts, would they override the enable scripts in my START macro, or does the START macro have the last say?
Thank you. I'll have to figure something else out or goo with status quo. I was hoping to feed TPU direct to the toolhead, bypassing the filament sensor (which on my 2.4 is mounted at the top of the back panel, and the Bowden tubing to the toolhead. I have printed TPU successfully in my present set up, I just wanted to improve the feed path. I also use a 3mm ID Bowden and wanted to change to a 2mm ID and tighten up the allowance on the motion sensor, right now I have to use 10mm. I find that 2mm ID tubing is too restrictive for TPU.
I guess that I could set a flag in the post processing script for the TPU profile, and then disable the sensors using an "If" statement in the START macro.
