New vorons
Hi I am wondering if any one has herd of and new voron builds coming up as a mate of mine and my self would like to build a bigger printer past the 350 I did debate about stretching a Trident but concerned to getting config right and getting build plates etc the rat rig looks nice but no one ships them here to Australia that I am aware of and damm they get expensive the hight is not such a concern for both of us mainly the build plate would like something enclosed 400 to 450 even 500 as bigger is always better hey
I have already re-engineered the cad drawing to 400mm and 500mm bed sizes. Having built the 400mm.
It's only technically a change in lengths of extrusions, linear rails and bed plate/heater nothing complicated.
Those files are not for public consumption though, been bitten in the ass about that before sorry
The Voron Design website allows you to select a non-standard size and then gives you all the details. The only part, as I understand it, you will need to handle is the bed dimensions. Even with this, there is a drawing that describes how to make the changes.
There are mods out there that change the belt width which, as I understand it, would be a good idea on machines larger than 350mm.
22 hours ago, claudermilk said:
Just saw this update on that thread.
Quote
We're running it as an internal beta. There are multiple operational at this point. Two should be at RMRRF in a week, but it'll still be a bit before it hits a full release. It is not usually our way to put out public betas, spec sheets, or CAD before the entire release package is ready.
https://forum.vorondesign.com/threads/phoenix-anticipation.1405/post-14945
That sounds promising.
Having watched this video Voron Phoenix
I love being proved correct, as anyone who wishes to look back on my old posts here you will see, I presented my own version of "TAP" with cross-slide bearings after tap was first released..... for the lead Voron guy to admit that a linear rail (for the tap application) was suboptimal is like vindication
Edited by Calvinx
spelling
