My Second Build: Modified Voron V0 (I named it "Recruit")
NewGradRN
The color scheme for this build is military jungle camo. I opted to source the parts for this build and also to utilize parts I have available including the parts I did not use from the V2.4 kit. I used 2020 for the frame to accommodate the 15mm THK rail and standard 1515 for the build plate mount and the X gantry. As I learned from the first build (Mods as I go), I am now just printing parts as I need them so I can make modifications as needed or desired. This V0 frame is 470mm tall without the hat and 270mm wide. TR8x8 lead screw and coupling to the motor. The weight of the Z with the HSR15 bearings really makes it heavy but at the same time makes me even more curious if it would work Hmmm... I have some new Nema 17 motors on hand (StepperOnline 45Ncm 12-24V) so I will try them first and see. My question is what board can I use that can accommodate 3A (for LDO 42STH48-2504AH just in case) but small enough to fit the V0. Thanks in advance for your inputs.
Just in case someone want to experiment, here's the Modified bed mount stl for THK HSR15. The bed plate extrusion and mounting specs are maintained.
Edited by NewGradRN
Remove unnecessary files.
It's been a while since last post. Current update to my Voron 0.2 with HSR15 Z. Assembly is 95% completed. Waiting for the LDO Nitehawk 36 to be in stock at KB3D. The added height and width enabled me to install an external carbon recirculating filter for the chamber. I used Hiwin MGN9C for both X and Y axis. For display, I used BTT 4.3 TFT. The rest are standard LDO V0.2 hardwares. All printed parts are printed with my V2.4. Still struggling to fine tune my V2.4.
